Thread: 3.4" vs 3.25" pulley
Results 1 to 20 of 24
  1. #1 3.4" vs 3.25" pulley
    Dec 2012
    Iv been reading a lot about supercharger pulleys on the forums but cant decide what the best route is to take. Should i get a 3.4" pulley with new plugs, ubend delete, intake, thermostat, pcm, and down pipe? or should i get a 3.25" pulley with all of the above plus new headers and will that be safe to do?
  2. #2 Re: 3.4" vs 3.25" pulley
    new britain, ct
    get the 3.4. get headers with it. anything below will require more modding.
    07 Black GXP.
  3. #3 Re: 3.4" vs 3.25" pulley
    Definitely 3.4
  4. #4 Re: 3.4" vs 3.25" pulley
    Read up more on modding before you buy anything.
    Sounds like you are going off of what ZZP says for this information.
    Exhaust first, then add air. While scanning the whole time.
  5. #5 Re: 3.4" vs 3.25" pulley
    I meant 3.4 with headers
  6. #6 Re: 3.4" vs 3.25" pulley
    Jul 2011
    B-Town, PA
    Isn't the safely modding thread required reading?
    if not. it SHOULD BE. this is all addressed in that thread. read, absorb...
    ...then ignore it anyways like most people...
    SMGPFC Member # 569 - Mad Monkey Approved!
    New Ride - 2012 CTS-V Coupe 6spd - Black/black, Recaros. Stock for now.
  7. #7 Re: 3.4" vs 3.25" pulley
    Kansas
    You can usually find headers for a little more or same as DP. Might as well get headers, and have a better flow.
  8. #8 Re: 3.4" vs 3.25" pulley
    Dec 2012
    okay thanks. I will most likely go with a 3.4 and just get headers when i can. after this what should i do besides going with a smaller pulley. what else can i do to gain power?
  9. #9 Re: 3.4" vs 3.25" pulley
    Kansas
    Headers first. One of the biggest restrictions for these engines is the exhaust manifolds. Need more exhaust out before you can add more in. And for power gain.... it all depends on what you want to do, and how deep your pockets are. Anything outside of 3.4" you are talking cam and so on. So the price to safely and effectively run more mods after 3.4" goes up quickly.
  10. #10 Re: 3.4" vs 3.25" pulley
    Sep 2011
    MI
    1.9 rockers are cheap
    or intercool it...
    or both..... all depends on how mch mony you have
  11. #11 Re: 3.4" vs 3.25" pulley
    Read the modding thread in the general tech section.
  12. #12 Re: 3.4" vs 3.25" pulley
    Dec 2012
    ok ill check out the modding thread. if i got a 3.4" pulley and did all of the supporting mods including headers and an intake what kind of torque/hp gains can be expected?
  13. #13 Re: 3.4" vs 3.25" pulley
    new britain, ct
    from what ive seen...youll have 230-245 whp with a good tune.
    07 Black GXP.
  14. #14 Re: 3.4" vs 3.25" pulley
    Dec 2012
    did u mean 330-345hp?
  15. #15 Re: 3.4" vs 3.25" pulley
    new britain, ct
    Quote Originally Posted by Slideways22 View Post
    no.
    07 Black GXP.
  16. #16 Re: 3.4" vs 3.25" pulley
    That kind of power isn't easy with a supercharger
  17. #17 Re: 3.4" vs 3.25" pulley
    Dec 2012
    stock gtp comes with 250 at least.. did u mean 230 additional hp?
  18. #18 Re: 3.4" vs 3.25" pulley
    Kansas
    250 crank hp..... ~200 wheel horse power. And no.... maybe 30-45 additional hp on top of the factory wheel depending on certain factors.
    So say ~230whp on the bottom side.
  19. #19 Re: 3.4" vs 3.25" pulley
    From the factory the Grand Prix GTP (97-03) have 240 Horsepower and 280 FT LBS Torque.
    Minus the drivetrain loss and your at 200/250 to the wheels.
    Do those mods for a 3.4 setup and you might be 230/280-290 to the wheels.
  20. #20 Re: 3.4" vs 3.25" pulley
    new britain, ct
    nope, i only meant that right now you make about 240 at the crank. maybe. so that means about 190-195 to the wheels.
    with a 3.4 pulley and supporting mods, you will make about 230-240 to the wheels. so that means about 280 to the crank.
    07 Black GXP.
  1. What size pulley is "TO SMALL"????
    By kenizzle36 in forum General Tech Discussion
    Last Post: 08-20-2011, 04:10 AM
