Thread: montecarlo engine into gtp?
Results 1 to 12 of 12
  1. #1 montecarlo engine into gtp?
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys. I have a 2000 gtp that needs a motor and i was wondering if I can take the motor from a 2005 Monte ss without any problems.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: montecarlo engine into gtp?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Yep. Both are L67.
    GPONA #1 Cyber Bully
  3. #3 Re: montecarlo engine into gtp?
    Jul 2012
    Clayton,NC
    i just put the same year motor in my 98 didnt have one problem.
    98 gtp- cammed intercooled slowness
  4. #4 Re: montecarlo engine into gtp?
    Orland Park, IL
    are you guys sure you dont have to change anything like the motor mount? cause im having trouble getting it to fit right.... its all the way down and the motor mount is in. Half of the engine is meeting with the trans and the mount with the 2 bolts by the firewall is like an inch too high... i dont get it
  5. #5 Re: montecarlo engine into gtp?
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    pics may help me on how it looks in the engine bay
  6. #6 Re: montecarlo engine into gtp?
    Are the motor mount brackets different?
    I would assume there are changes from a 05 monte to a 97-03 grand prix.
  7. #7 Re: montecarlo engine into gtp?
    Jul 2012
    Clayton,NC
    I had the same problem with the motor going in and it was all the flexplates fault. There is a small hole in the middle of the flexplate that has to line up with the button on the middle of the torque converter. Only way to see it is with a flashlight looking up between the two of them. Gt them lined up and should go right in
  8. #8 Re: montecarlo engine into gtp?
    Often you need to jack the passenger end of the trans up to meet up and allow things to line up. Lining up the engine to trans can be a pain for a first timer. It's a bit of luck/experience and a lot of wiggling and adjusting of angles.
  9. #9 Re: montecarlo engine into gtp?
    Dec 2012
    troll land
    the 05 monte is a series III
  10. #10 Re: montecarlo engine into gtp?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by l67ss View Post
    Nope.
  11. #11 Re: montecarlo engine into gtp?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Lol.
    Negative Ghost rider.
  12. #12 Re: montecarlo engine into gtp?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    if i remember correctly, gm mixed the L32 and L67 in 04-05 for the imps and montes. L32 blocks with L67 heads and blowers
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. sway bar for 2003 montecarlo
    By minnesotanice2009 in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2008, 12:39 AM
