Thread: About ready set car on fire..
Results 1 to 19 of 19
  1. #1 About ready set car on fire..
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    Nothing but problems after engine swap... Engine idals rough and misfires in most cylinders... Vac lines are new.. The car runs way better with the maf unplugged but the maf is new and just to make sure I exchanged it and the new new one is the same... Fuel line pressure is fine.. New fuel filter.. The car excellerates great but just idels like **** and the dash lights dim and brighten... Today while playing around with the radio I found that if I turn the key one turn the radio has no sound and the lights flicker tell I start it or turn it back... Could a short be causing all my problems or did I miss a damn ground when I did the swap... I got the grounds under the starter to the tranny and a ground by the pullies but are there anymore I forgot about... I've been rechecking everything all week and haven't got any codes and I have a spare ECM and that wasn't it... The only thing I haven't checked is air leaking in from the injector O rings but wouldn't that leak fuel?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    What year is your ecu and what style maf are you running
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  3. #3 Re: About ready set car on fire..
    GT Level Member Beelzeboul's Avatar
    Racine
    did you check the ICU bracket ground ?
    I'm sorry officer I didnt know I couldn't do that
  4. #4 Re: About ready set car on fire..
    Year of car and description of work done please. Need to know if this was a simple swap or more involved.
  5. #5 Re: About ready set car on fire..
    Yoga city
    just burn it, not with keys in it though lol
  6. #6 Re: About ready set car on fire..
    Cambridge, Ontario Canada
    They are designed to set themselves on fire, just give it time! Mine did 3 years ago...
    2005 E55 - stock
  7. #7 Re: About ready set car on fire..
    Lack of maintenance causes that Elite. You may have wanted to fix that oil leak..lol
  8. #8 Re: About ready set car on fire..
    Out West
    In for video of burning GP
    Whine with your Cheese?
  9. #9 Re: About ready set car on fire..
    Yoga city
    wanna roast marshmallow on the open hood fire, o what a time it would be!
  10. #10 Re: About ready set car on fire..
    Ok guys.. let's bring this back to why the OP is posting.
  11. #11 Re: About ready set car on fire..
    Yoga city
    uhm the op has no knwoledge of fire, oil helps it, gas helps. look for theese things. mailny gaskets
  12. #12 Re: About ready set car on fire..
    Nov 2009
    canada
    It's a 2001 L67 to a 98 gtp swap.. I used the 98 wiring and throttle body and ecu... Where is the ground for the icm? I'm guessing it was the ground wire by the supercharger belt tensioner? If so yes that ground is on and I'm thinking if I had missed it the car wouldn't start anyway...
  13. #13 Re: About ready set car on fire..
    Nov 2009
    canada
    The only thing changed on this engine is I added 1.9 rockers and there's no noise or ticking so I'm guessing those are on right...
  14. #14 Re: About ready set car on fire..
    Nov 2009
    canada
    When I get home from work I'm going to check the injector bottom O rings for leaks as I swapped the injectors from the 98 to the 01 and I'm thinking they're not sealing properly, maybe... My last guess lol next step is slamming my head in the door...
    GT Level Member tylerbinski's Avatar
    Canada
    No scan gauge?
    That would help u out a lot
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  16. #16 Re: About ready set car on fire..
    Nov 2009
    canada
    I have a scan gauge but I'm not sure what I'm looking for... I just use it for KR.. I watch the maf readings and unplugged it's at 30 and at idle it's bouncing around 43 when plugged back in..
  17. #17 Re: About ready set car on fire..
    check the wires to the maf for cracks or bare wire showing, also check for a blown fuse. when the fuse blows the maf dont work right.
    are you getting a code for the maf as well?
  18. #18 Re: About ready set car on fire..
    Nov 2009
    canada
    I don't get a p0102 code tell I get the rpms up to 5k I've checked the fuses a while ago and they're all good... This weekend I'm going to pull out the wiring harness and check...
  19. #19 Re: About ready set car on fire..
    Couple of things I'd try first.
    Spray around the motor for vacuum leaks.
    Pull the EGR tube from EGR to LIM and check the end that goes into the LIM, it's commonly cracked where the piece holds it in.
    Do a crank learn. I know..yo.....wait.
    Who's 1.9 rockers? ZZP modded rockers require the rocker pedistals to be modded as well.
    Back to the crank learn. I've had a couple cars run like crap. Nothing helped. A crank learn straightened them right up.
  1. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  2. Ready to go!
    By Schoop in forum Introductions/Noob Questions
    Last Post: 01-25-2011, 08:33 PM
  3. getting ready
    By newmarketgtp in forum Introductions/Noob Questions
    Last Post: 05-14-2010, 02:34 PM
  4. I'm ready to have some fun with a GP
    By Chmanzi in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 11:18 PM
  5. Hey all! Get ready!!
    By 69Fiat in forum Introductions/Noob Questions
    Last Post: 08-09-2009, 11:01 PM
