Thread: gtp 1998 to 2002 gtp engine swap help needed
Results 1 to 4 of 4
  1. #1 gtp 1998 to 2002 gtp engine swap help needed
    Jun 2012
    Terrebonne,Quebec,Canada
    i have a 1998 gtp totaly rusted so last month i had the chance buying a 2002 gtp shell so i took it.
    So i have take my 1998 engine,engine harness, pcm and tranny to swap in the 2002. now when i try to start it it turn but no fuel come in rail, no spark plug fire, key stay stock in ignition, shifter still lock , door bell ``ring`` when the keys are not in the ignition,no headlight and no front flasher rear is ok, fuel gauge show full all time now im really confused about all that !!! doe the harness is incompatible or the pcm ? is it possible it came from the security system?
    finally excuse my possible mistake in english im french !!!! and want to say thank in advance for your help guys
  2. #2 Re: gtp 1998 to 2002 gtp engine swap help needed
    you need to use the pcm and harness from the 02 shell car. its set up to use the vin from that car, year to year swaps dont always work.
    if thats what you did, im not sure, you dont say.
    check all grounds as well.
  3. #3 Re: gtp 1998 to 2002 gtp engine swap help needed
    Jun 2012
    thank to reply i use the 1998 pcm and harness because the 2002 was not in the car, for the ground i have look but i'll double check thank do you think if i get a 2002 gtp pcm reprogram with my vin and get a 2002 harness will solve my trouble ?
  4. #4 Re: gtp 1998 to 2002 gtp engine swap help needed
    you may be able to get the 98 flashed with the vin of the new car, im not 100% sure though.
    either way you going to need someone who can tune a pcm to do it.
  1. Engine swap in 2002 Grand Prix SE
    By 719CJ in forum General Grand Prix Discussion
    Last Post: 04-07-2012, 07:18 PM
  2. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  3. 2002 GTP engine swap
    By gtppwr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2011, 10:23 PM
  4. 1998 Grand PRix GT engine swap
    By 98 Grand Prix Gt in forum General Tech Discussion
    Last Post: 01-19-2011, 11:46 PM
  5. 1998 Grand Prix GT engine swap
    By aandbclark in forum General Tech Discussion
    Last Post: 12-03-2009, 08:04 PM
