Thread: zzps xpz cam
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 zzps xpz cam
    SE Level Member GTPAIELLO's Avatar
    Aug 2012
    weymouth, ma
    like or dislike? Thinking about purchasing one witha set of there s4 heads
  2. #2 Re: zzps xpz cam
    LOL stage 4 vendor heads for a trillion doll hairs.
    You must have money burning a hole in your pocket.
    And no, not a huge fan of the XPZ and it's lame specs.
  3. #3 Re: zzps xpz cam
    since there is no other info, no, don't like.
    Why? because I dont like it.
  4. #4 Re: zzps xpz cam
    The Boss Iceman6669's Avatar
    Jun 2011
    I have heard both ways... BUT.. Here is what it can do
    10.82@126 record M90 3800 car - YouTube
    2011 F-150 Yote powered
  5. #5 Re: zzps xpz cam
    Jan 2012
    Philadelphia
    would you guys recommend running an IS3 cam over a XPZ?
    Ohio
    Josh you know why zacks car ran that fast?
    Weight reduction... you posting that video is completely irrelevant to this discussion.
    Dyno comparison sheets are the true facts for this.
  7. #7 Re: zzps xpz cam
    Jun 2011
    Quote Originally Posted by 99pgpgt View Post
    I just said what it CAN do.. Not what it does every time....
  8. #8 Re: zzps xpz cam
    What it CAN do with plenty of platform know how and tons of time and tuning.
    No thanks.
    For that money, upgraded valve springs, intercooled Z3 kit, custom WB tune...faster car.
    The end.
  9. #9 Re: zzps xpz cam
    Quote Originally Posted by gtpeddie View Post
    no.
    IS3 has more top end than an XPZ.
    You're making a street car right?
    Ohio
    So once again...we're going to turn this into
    ..a big supercharged setup is a waste of a couple thousand if not more..
    A simple turbo kit, will not only gain you the same numbers...but cost a lot less.
  11. #11 Re: zzps xpz cam
    Jan 2012
    Philadelphia
    yea street car Matt, and im not looking to put 1000's into it im gonna get my heads ported for cheap and run a cam springs and a few other goodies
  12. #12 Re: zzps xpz cam
    But if you already have the cam, just run it.
  13. #13 Re: zzps xpz cam
    Aug 2012
    weymouth, ma
    Hi started this thread. i have intercooler, ported lim, tb, sc, injectors, headers, and exhaust. wanted to get cam, heads, lifter, roller rockers. spending some money before i buy a house
  14. #14 Re: zzps xpz cam
    Jan 2012
    Philadelphia
    i dont its just that the xpz is like $480 and the IS3 is like $325
  15. #15 Re: zzps xpz cam
    Wut.
    It comes with $115 worth of pushrods.
    OP: You didn't state your goals, priorities, driving style, use for vehicle, etc etc etc etc etc. And once you have all of that, you should be able to make the decision for yourself.
  16. #16 Re: zzps xpz cam
    Jan 2012
    Philadelphia
    damn im an idiot didn't really read that lol
    OP not trying to thread jack
    so you think im better off with an xpz then an IS3 for a street car?
  17. #17 Re: zzps xpz cam
    Aug 2012
    weymouth, ma
    street car, 4th car so it would'nt have to be a daily driver. and my goal is to produce alot of hp. and have fun driving it.
  18. #18 Re: zzps xpz cam
    Either cam will work.
    Its like trying to decide between an XP or S1X.
    Unless you're going to go to the ends of the earth to try and make high 300's or low 400's, either will suffice.
  19. #19 Re: zzps xpz cam
    Aug 2012
    weymouth, ma
    well i already had the Is1 cam with lifter, roller rockers, rods, with an intercooler. Im lookin for more hp. I plan on bringing it the the track. Im looking to have that feel of a cammed out motor
  20. #20 Re: zzps xpz cam
    Banned
    Jun 2012
    Sacramento CA
    Personally I'd take the IS3 over the XPZ. I know people who daily drive both... neither are big enough to cause drivability issues. Although swapping out your current cam for a bigger one with heads isn't going to give you the kind of power increase you probably think it will. The IS1 cam is already a big jump over stock.
    Good luck with whatever you decide on!
  1. XPZ SETUP....and zzps thoughts
    By shawn in forum General Tech Discussion
    Last Post: 07-30-2010, 05:19 PM
