Thread: 2002 GTP engine swap
Results 1 to 4 of 4
  1. #1 2002 GTP engine swap
    Edison, NJ
    Hey guys, I'm about to swap out my 2002 gtp engine for a 1998 engine. Is there any differences in these 2? the original engine started smoking a cloud of White smoke and the body has 140k on it, found a 98 gtp engine complete minus alternator and a/c with 82K miles on it. Did notice oil pan was dented on the 98 but i already got the gaskets and will swap the 02 oil pan over...But the real question is if i need to swap anything else from the 02 engine or vise versa. thanks for your input
  2. #2 Re: 2002 GTP engine swap
    I bet the LIM gasket blew out on you first motor. Thats an easy fix.
    But as for the motor, It should be a direct swap.
  3. #3 Re: 2002 GTP engine swap
    Edison, NJ
    Thats what i thought..But when i pulled spark plug number 1 the whole electrode was gone!! and when i remove the oil cap pure white smoke is pouring out..could that still be a LIM?
  4. #4 Re: 2002 GTP engine swap
    Edison, NJ
    I was going to start to remove engine tomorrow. I will first remove the LIM and check it doesn't hurt and if its good i'm going to go ahead with removal.
  1. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  2. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  3. Engine swap
    By unit2428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2010, 07:54 PM
  4. engine swap
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2009, 03:11 PM
  5. Engine swap?
    By Spacedonut in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-24-2009, 02:01 PM
