Thread: Should I bother to "pulley down"?
Results 1 to 10 of 10
  1. #1 Should I bother to "pulley down"?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Running SSAC headers, Open Cone Intake, all stock otherwise (stock T-stat and plugs). Running 93 Octane.
    Was considering a 3.4"-3.5" pulley setup, but at my mod level, is there any reason not to run stock pulley and just have the timing advanced? What advantage does a smaller pulley with less timing have?
    I obviously need to be retuned for either anyway. Figure I can pocket the 50-100$ I'd spend on a pulley/MPS if there is no advantage to a pulley drop over adding more timing.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Should I bother to "pulley down"?
    Cambridge, Ontario Canada
    I think you can run a 3.4 but you'll need to scan to be sure. Timing makes a big difference IMO but I think you can rock a smaller pulley with no timing loss. Go 3.5 to be safe with at least an aftermarket computer! I am looking at a 3.4 with my mods right now.
    2005 E55 - stock
    Pulley > timing in terms of how the car feels imo.
    Id say run the smallest pulley you can get away with on stock timing/fueling.
    If the car pulls any timing id suggest a larger pulley.
  4. #4 Re: Should I bother to "pulley down"?
    Knoxville, TN
    Alright. I'm going to run this car on the conservative side, as it is my DD. I was thinking a 3.5" pulley would be my best bet for safe year-round operation. I want 0* of knock under all conditions, even if I have to sacrifice some timing.
  5. #5 Re: Should I bother to "pulley down"?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by GTP131 View Post
    meh, these cars love to knock for most people. For some reason some cars I tune are just KR cursed.
  6. #6 Re: Should I bother to "pulley down"?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    my car lol^^^^^^^
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  7. #7 Re: Should I bother to "pulley down"?
    Quote Originally Posted by asite57 View Post
    my car lol^^^^^^^
    Because of other issues
    Last bit read that again.
  9. #9 Re: Should I bother to "pulley down"?
    Knoxville, TN
    I caught it the first time, I was just looking for some hard numbers rather than what your butt dyno says. lol, no offense Matt.
  10. #10 Re: Should I bother to "pulley down"?
    Oct 2011
    Michigan
    Haha yea blue hopefully its all running good soon
  1. What size pulley is "TO SMALL"????
    By kenizzle36 in forum General Tech Discussion
    Last Post: 08-20-2011, 04:10 AM
  2. Supporting mods for 3.4" - 3.2" Pulley
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2008, 12:33 PM
