Thread: boost bypass
Results 1 to 6 of 6
  1. #1 boost bypass
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    when my bbv is connected to the solenoid i only get 3 psi of boost, then i undo the vacuum line going from the bbv to the solenoid i get 7 to 8 psi. , is the solenoid bad or the bbv?
    Dec 2010
    DMV
    Solenoid
  3. #3 Re: boost bypass
    Sep 2012
    bridgeport,NY
    would it throw a lean code i been getting p0171
  4. #4 Re: boost bypass
  5. #5 Re: boost bypass
    The lean bank one is something else. Often vacuum line related
  6. #6 Re: boost bypass
    Which means you need to check all the rubber "T" fittings and plastic vac lines around the blower/LIM/TB/MAP/FPR, etc.
  1. Boost Bypass Actuator
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 08-14-2013, 05:47 PM
  2. boost bypass mod
    By mcsddd in forum General Tech Discussion
    Last Post: 08-19-2010, 07:50 PM
  3. Boost Bypass Valve help
    By mikeh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2009, 01:20 AM
  4. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  5. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
