Thread: Valve cover removal
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: Valve cover removal
    Denver
    I have caftsman deep well sockets and huskey deep well sockets. Only the craftsman will reach this nut and stud. The huskey misses is by about 1/2". Even the craftsman cannot be fully clicked on the extension.
  2. #42 Re: Valve cover removal
    my husky set is all i have, so i used it and it worked. it is a deep stud tho. mine are 12 point, dont know if that matters.
  3. #43 Re: Valve cover removal
    Slower, Lower Delaware
    Thanks for the help. I need to do this as efficiently as possible my RA makes this kind of stuff harder. Getting old is hell.
  4. #44 Re: Valve cover removal
    blueguy91: Valve covers off didn't pull the elbows. Thanks.
  5. #45 Re: Valve cover removal
    Look so good I need a see-thru VC. I didn't get grommets with my vc gaskets.
  6. #46 Re: Valve cover removal
    have you started it yet?
    Did you Loctite the rocker bolts?
    I know I had to go back in and re-torque the reusable bolts twice which is why I started Loctiting Comp bolts...trust me, a rocker bolt backing out at WOT halfway through 2nd is kinda sketchy, LOL.
    There are also tons of different opinions on the TQ. spec...stock is like 11-12 on the TTY bolts, but the Comp bolts go anywhere from (that I've seen) 21 ft. lbs. to 27 ft.lbs.
    I think I ended up getting 25 as the magical # + Loctite to finally shut the valvetrain up
    And yeah, grommets...pffft.
  7. #47 Re: Valve cover removal
    I did locktite the reusable bolts I did 23#. Still didn't get it done, had "family" stuff I had to do. I did pick up some Felpro grommetts while I was out.
    ALSO.. It looks like I have a leak around the front elbow. I guess I'll do them while I'm this far. Where can I pick up those dorman metal elbows? Are there just the two, one short one and one longer one?
  8. #48 Re: Valve cover removal
    Yeah, I think as of yet you still have to buy them online...and they are like 5~ bones.
    I'd order them but just buy the cheapo plastic HELP! section ones and RTV the crap out of them.
    Never had any leak issues...evah.
  9. #49 Re: Valve cover removal
    Spun the engine over to see if everything moved freely. Looked good so I put the Valve covers on. I'll start bolting stuff back on that won't matter to the elbows when ever I have a few minutes. Work tomorrow and a family trip Friday. Maybe in a few days I'll get some more real time to work on it. I hope these rockers help my KR.
  10. #50 Re: Valve cover removal
    Pretty, not really a visual part of the car though. Ready to start putting it back together.
  11. #51 Re: Valve cover removal
    All back together. Drives nice. Haven't checked KR or Boost. Temp gauge fluxuated a little on the way to work. It just moved from the first big mark, up two, and back down. It usually stays at the first big mark since I put the 180* in. I Hope I got all the air out, I'll work on that again tonight just in case.
    GTP Level Member Ultra440's Avatar
    Ohio
    I just did mine as well. Checked around locally for the aluminum elbows but no dice. Got the covers painted while I had them off tho, so that was a plus.
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  13. #53 Re: Valve cover removal
    I had to order the elbows from Dorman, Had them shipped 1-2 day. Shipping was more than the parts.
  14. #54 Re: Valve cover removal
    SE Level Member dblisle's Avatar
    May 2012
    Keene, NH
    Looking at the leak, I'm noticing that I'm down a 1/4 of a quart in about a month. I haven't down one of these before so if anyone is in the Keene, NH area I'll need a hand working on the rear cover since it is covered by the super charger.
  15. #55 Re: Valve cover removal
    The rear cover isn't covered by the supercharger its behind it.
  16. #56 Re: Valve cover removal
    May 2012
    Keene, NH
    How difficult is it to remove with removing the Supercharger?
  17. #57 Re: Valve cover removal
    it would be just as hard to change with or with out the sc on the engine. its not in the way. you need to remove the alt, and the sensor back there, takes about 30 minutes to complete.
  18. #58 Re: Valve cover removal
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by dblisle View Post
    Holy Sh1t!!! The rear VC IMO is easier than the front. Just remove enough things until you can get that VC out. If your not mechanically inclined, you might have to pay to get it done. Not trying to be a dick bro, but "really". There are tons of write ups on this site. The search bar up at the top hiding is a great place to learn from. Hope you get it fixed. Oh and try not to highjack anymore threads.
  19. #59 Re: Valve cover removal
    May 2012
    Keene, NH
    Texas Tanker, Thanks for the advise I wasn't trying to Hijack the thread, I'm Mechanically inclined however, I haven't done this before and I'm doing my research prior to jumping in and having my car off the road for a few hours or days. So please leave the attitude offline.
  1. Rear valve cover removal
    By Angleiron in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-02-2012, 11:58 AM
  2. EGR valve cleaning and removal
    By JAXSON in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2010, 12:09 AM
  3. Front Valve Cover Removal
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-26-2008, 05:52 PM
  4. Rear Valve Cover Removal
    Last Post: 08-24-2008, 12:46 PM
  5. Valve Cover Removal
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 07:19 PM
