Thread: Rear Valve Cover Removal
Results 1 to 14 of 14
  1. #1 Rear Valve Cover Removal
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    What all needs to come off to get the rear valve cover off ? i have already gotten something off it just won't come out and i would like to know if i missed something and that is why it is hung up
  2. #2 Re: Rear Valve Cover Removal
    Bastard Reptile's Avatar
    Kansas City, MO
    Did you take the alternator bracket loose?
  3. #3 Re: Rear Valve Cover Removal
    Apr 2008
    Chillin at the Beach , VA
    And make sure that all the clips hoding any wires are undone so they can be moved around also. Gotta figure out what way it will slide out from underneath everything. Do like Reptiile said and it Will probably come out easier. I di it witout taking the bracket off. Can be done, but a major pain.
  4. #4 Re: Rear Valve Cover Removal
    St. Louis
    yea i did everything else tho so i will have to try to remove the bracket and hopefully that will help me out
  5. #5 Re: Rear Valve Cover Removal
    Banned
    Wichita Falls, Texas
    Make sure everything is clean around the injectors and such before you take it off as well, that way you don't have dirty junk falling into your motor.
    Just a tip.
  6. #6 Re: Rear Valve Cover Removal
    PA
    Yeah, I had to take the alternator bracket off when I tried to remove mine.
    Just beware that coolant flows through your alternator bracket.
    2001 GSE
  7. #7 Re: Rear Valve Cover Removal
    St. Louis
    fun.... thanks for letting me know that
  8. #8 Re: Rear Valve Cover Removal
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    '97-'98's the bracket doesn't need to come off, only the alternator. There is an upper bracket on the '97-'98's will hinder your task, but no coolant loss.
    '99+ the bracket needs to come off..... Be prepared to replace the 2 coolant elbows that incorporate the bracket into the cooling system.
    Can't remember if the EGR valve is in the way or not.
    Remember, there is a valve train under that cover so it needs to lift straight off.
  9. #9 Re: Rear Valve Cover Removal
    St. Louis
    yea it was just the alternator that was in my way after that come of it was all easy going
  10. #10 Re: Rear Valve Cover Removal
    Apr 2008
    So did it not have a gasket on the rear?
  11. #11 Re: Rear Valve Cover Removal
    St. Louis
    it was missing a part of it, actually it looked like someone just made a gasket out of the high temp gasket maker (the orange stuff) so i have a feeling it didn't set right so i got a new gasket and it took care of the problem for me
  12. #12 Re: Rear Valve Cover Removal
    Apr 2008
    Happy to hear that. It kills me when people try to take the cheap way out and cause more problems than what it's worth.
  13. #13 Re: Rear Valve Cover Removal
    St. Louis
    yea me to the sad part is that the gasket doesn't even cost that much
  14. #14 Re: Rear Valve Cover Removal
    Apr 2008
    exactly!
  1. Rear bumper removal - 2004 GTP.
    By Edmonchuck in forum Visual/Body Modifications
    Last Post: 11-21-2008, 01:01 PM
  2. Valve cover gaskets
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2008, 07:34 PM
  3. Front Valve Cover Removal
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-26-2008, 05:52 PM
  4. New valve cover and redone FWI
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 03-15-2008, 02:46 AM
  5. Valve Cover Removal
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 07:19 PM
