Closin in on 200k
just redid gaskets and other maintance on the car stripped most I the block down
been sitting for about 6 months with the same gas. There is a sea foam in this gas now and there was some in the oil before I changed it
In the vid the motor has just the serpentine belt on and very little coolant
this is the first fire up since I've fixed everything. Oil pressure is good
sound seems to be coming from inside the valve covers I'm not sure. The scan gauge says no misfires so idk what's goin on
altho I think it could have to do with bad wires
04 comp g btw
