Thread: need help white plugs
Results 1 to 5 of 5
  1. #1 need help white plugs
    SE Level Member shawnheck03gtp's Avatar
    Billings, MT
    so my car has developed a problem gradually when i built my car i had no kr but it seems to be gradually getting worse like 5.8 deg kr at the top of second gear and i dont have a wide band but my 02s are between 945-955mv. and the timing jumps from 15 to 17 at the top of each gear. and at the top of each gear my boost spikes 2 or 3 psi and the plugs are white so lean so i need help please
    03 gtp, 3.25 mps, speed daddy headers, vs cam, (sh***Y)zzp pcm, fwi, catback, warboro fuel pump, 14.15 at 99.84mph best 1/4 mi with a badly slipping tranny
  2. #2 Re: need help white plugs
    Florida
    prob #1 zzp pcm
    prob #2 no wide band O2
    prob #3 3.25 pulley when having Kr and lean AF
    pulley up until you can fix the issue. if someone is close by get a tune and fix prob #1 and the prob in question
  3. #3 Re: need help white plugs
    Billings, MT
    i understand all that but i dont understand why it ran good when i first built it. could a fuel filter or pump really cause this issue and the other problem is that there is nobody around here to tune so im solo on that one (i live in billings mt)
  4. #4 Re: need help white plugs
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    whats so bad about zzp pcms
  5. #5 Re: need help white plugs
    Quote Originally Posted by shawnheck03gtp View Post
    Probably the same Shawn I've talked to on FB?
    Idk, if not...you can't expect a canned PCM to work with that thing, it needs a custom tune. Bar none. Yank the blower belt off and drive it to someone and have them tune it. /end.
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Plenty.
    Look into it.
  1. Frost White GTP
    By gtpeddie in forum Members Rides
    Last Post: 08-31-2024, 10:38 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
