Thread: Key stuck and car won't shift out of park
Results 1 to 11 of 11
  1. #1 Key stuck and car won't shift out of park
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    So I swapped the engine in my 98 gtp and it's running great exept after the swap the key won't turn past the lock and the sifter is stuck in park... On a side note the lights sowing if you're in park reverse drive isn't lighting up... Any ideas?
  2. #2 Re: Key stuck and car won't shift out of park
    GT Level Member Beelzeboul's Avatar
    Racine
    sounds like you should remove your ignition switch solenoid and clean up the contact on it if that does not work it may be a theft system issue or parking switch which you can also remove and tape down so you never have to worry about it again
    the fact that its not leaving park is kinda what gets me normally if the parking switch isnt hit you can turn the key to on and flip it into park once or twice more till you hear a click and remove key than
    did u use a matching pcm for the new engine or keep the old one?
    I'm sorry officer I didnt know I couldn't do that
  3. #3 Re: Key stuck and car won't shift out of park
    Nov 2009
    canada
    It was an engine and tranny swap.. The tranny is from the 2000 gtp. That's what has me stumped is maybe one or the other going but both at the same time... It's almost like the car still thinks its in park.. I can use the sifter release and drive it but it's a pain and I don't want to have to keep using the shifter and key release every time I drive the damn thing
  4. #4 Re: Key stuck and car won't shift out of park
    Nov 2009
    canada
    Maybe it's the PCM.. It got rained on but everything else is working fine.
  5. #5 Re: Key stuck and car won't shift out of park
    Nov 2009
    canada
    Sorry I meant its like the car thinks its in drive when it in park... ^^^
  6. #6 Re: Key stuck and car won't shift out of park
    Nov 2009
    canada
    Nah all the plugs are in... Maybe it damaged on install.. Which pluge it the range sensor?
  7. #7 Re: Key stuck and car won't shift out of park
    Nov 2009
    canada
    I used the PCM for my 98.. It was all working fine before I pulled the engine.
  8. #8 Re: Key stuck and car won't shift out of park
    Mar 2012
    NC
    Maybe you forgot to hook up that shnazzy plug on the trans for the range sensor?
  9. #9 Re: Key stuck and car won't shift out of park
    Mar 2012
    NC
    the one under the master cylinder on top of the trans next to the shift cable bracket thingymajiggy
  10. #10 Re: Key stuck and car won't shift out of park
    Racine
    well I know with some pcms a case relearn is needed but it wouldn't start if that was the case
    thought for a moment maybe having a different vin number on new engine might trigger the theft system but check the video and see if it helps
    that parking switch lock is easily accessed bypassed
    2002 Pontiac Grand Prix "Press Brake to shift from Park" switch fix - YouTube
    this is a good breakdown of the same problem and the components
    u can see the button he presses in on the new switch would be what you wanna toggle to see if this is the issue
  11. #11 Re: Key stuck and car won't shift out of park
    Wichita
    This happened to me. I ended up having to OH the tranny. And, there was also a note on the statemwnt that said my shifter switch on the tranny was dirrty. You might try check to make sure that shifter switch is clean.
  1. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  2. Car stuck in park, key isn't stuck though
    By capitalcrew in forum General Tech Discussion
    Last Post: 05-03-2012, 10:28 PM
  3. Please help. Why am I stuck in park?
    By o0civicex in forum General Grand Prix Discussion
    Last Post: 03-24-2012, 08:45 PM
  4. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  5. Stuck in park
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2010, 10:37 AM
