Thread: what are minimum mods for topswaping? not in the guides
Results 1 to 6 of 6
  1. #1 what are minimum mods for topswaping? not in the guides
    Florida
    ok so im getting ready to topswap at the end of the month and was looking over all the modding guides and i can not find a list of the minimum mods in order to run a 3.8" pulley on a l36. i know most topswap kits come with/recommend a larger pulley. and i was told a 3.8 on a topswap is similar to a 3.4 on a l67....
    1) min mods to safely run a 3.8 topswaped
    2) is a 3.8 topswap = 3.4 l67?
    3) i will have the following mods: intake, ported TB, gasket matched LIM, ported heads, Si valves, SD headers, no cat, 2.5" catback, tuning.
  2. #2 Re: what are minimum mods for topswaping? not in the guides
    You have the mods to run the 3.8
  3. #3 Re: what are minimum mods for topswaping? not in the guides
    Also 3.8=3.6 ish
  4. #4 Re: what are minimum mods for topswaping? not in the guides
    new britain, ct
    i doubt theres a set formula when it comes down to it.
    its safe to assume that 3.8 top swap is like 3.4-3.6 l67.
    your ported heads will really help with the flow. because of that, you can probably even drop to a 3.6 on your top swap setup, but the only way to be sure of that is to throw the 3.8 on there and see how that runs.
    07 Black GXP.
  5. #5 Re: what are minimum mods for topswaping? not in the guides
    Florida
    Normally they go with a 4" pulley. You look safe to run the 3.8" with your mods.
    Not sure about the boost levels compared to the L67 though. Gonna have to check and see what kind of boost you're making on your setup.
    Though with your tuning skills, you should be able to get down to a 3.6" safely.
    One thing really: headers.
  1. Who needs TB adapters made? Looking to have a group by of 4 more minimum
    By 16MustangVet in forum General Grand Prix Discussion
    Last Post: 08-06-2012, 06:17 PM
  2. Minimum posts for classifieds access?
    By Ultra440 in forum Off Topic Discussion
    Last Post: 06-21-2012, 01:56 PM
  3. do i need machined guides for xp cam?
    By WOTFTW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2011, 09:11 PM
  4. Very Minimum Mileage on oil change.
    By White Ghost in forum General Tech Discussion
    Last Post: 02-10-2011, 02:57 PM
  5. Autozone Tech Guides
    By BlitzGT in forum General Tech Discussion
    Last Post: 06-12-2008, 01:22 PM
