Thread: zzp fuel pump rewire
Results 1 to 4 of 4
  1. #1 zzp fuel pump rewire
    SE Level Member Hawkman's Avatar
    Jun 2010
    North east, WI
    Hey just wondering if someone can get me pictures of how they did there wiring for the rewire and what wire they tapped into i kniw the instructions say the gray wire but? really zzp! ipulled of the fuse cover block and see the gray wire that goes into the pannle and cut it to have a little extra hanging out and hooked up the bluewire to the wire coing out od the fues box. hooked the rest up in the back installed new grounds and car starts and runs for 3-5 sec and dies the power to the pump stops wtf is going on? am i missing something or doing this wrong ? Thanks for any help
    all stock just as the car was intended!
    Quincy, Mass
    When cut the gray did you splice both ends to the blue wire or just the one coming from the fuse box?
    I personally didn't like the zzp rewire, it was poorly made. The Casper rewire, found from Wbodystore, or the racetronix, found on prj performance, is a much better quality rewire.
    No more GP 04 Impala SS Indy:
  3. #3 Re: zzp fuel pump rewire
    Jun 2010
    North east, WI
    i did not splice both ends only the one coming out of the rear of the fuse pannle. If i known how crappy it was i would have went with one of the others now lol. live and learn! so splice both to the blue wire then your saying? thanks
    Quincy, Mass
    Yes splice both to that blue wire.
  1. fuel pump rewire benefits
    By Warbeaver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2009, 10:12 PM
  2. Fuel pump rewire kit ?'s
    By basshead42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 06:25 PM
  3. fuel pump rewire
    By justwhisen in forum General Tech Discussion
    Last Post: 03-16-2009, 05:28 PM
