Thread: 01 GTP acceleration issues.
Results 1 to 7 of 7
Yarbeau 01 GTP acceleration issues. 07-28-2012, 04:32 PM
Rico Re: 01 GTP acceleration... 07-28-2012, 06:34 PM
Fivefingerdeathpunch Re: 01 GTP acceleration... 07-28-2012, 09:06 PM
Yarbeau Re: 01 GTP acceleration... 07-29-2012, 10:08 AM
Rico Re: 01 GTP acceleration... 07-29-2012, 04:05 PM
Yarbeau Re: 01 GTP acceleration... 07-29-2012, 06:27 PM
Timing Re: 01 GTP acceleration... 07-31-2012, 10:54 PM
  1. #1 01 GTP acceleration issues.
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    Have an 01 GTP only mod is a k&n intake.
    Got home from work car ran fine. Came outside and started the car up 20 minutes later and under any boost at all the car surges, pulses, shakes... I don't know the word to use. Its trying to boost but can't. My initial thought was MAF sensor. unplugging it changes nothing.
    Took it to a mechanic he had it for a few days and couldn't figure out anything at all..
    NO service lights are on, no codes come up with a computer. I'm stumped.
    Is it an internal vacuum leak? anyone have any suggestions? plug? maybe wiring or injector?
    Ill take a video this afternoon and post exactly what its doing. Starts idles and runs fine until you start boosting.
    Derek
  2. #2 Re: 01 GTP acceleration issues.
    Apr 2009
    Fort Worth TX
    What would be helpful is a list of everything the mechanic did/checked.
  3. #3 Re: 01 GTP acceleration issues.
    So your lego's bar doesnt go full?
    Hook up a real vacuum gauge and see what it does.
  4. #4 Re: 01 GTP acceleration issues.
    Jun 2010
    Edmonton
    Tested Maf, ran for codes, changed EGR, tested plugs and wires... Thats it.
    I'm thinking maybe a bad fuel filter? When I need higher levels of fuel I just can't get it and it causes the issue?
    Exactly my lego meter just bounces around jolting full then losing it all, going back up to half then down to a quarter etc...
  5. #5 Re: 01 GTP acceleration issues.
    Apr 2009
    Fort Worth TX
    It sounds like the supercharger belt is slipping.
  6. #6 Re: 01 GTP acceleration issues.
    Jun 2010
    Edmonton
    It could be something as simple as a new belt?
  7. #7 Re: 01 GTP acceleration issues.
    gardner,mass
    sounds like youe mech is retarded and you shouldnt bring your car back to him
  1. acceleration issues
    By tmackster in forum Engine
    Last Post: 05-09-2013, 02:11 AM
  2. 2005 GTP Acceleration issues Bogs
    By Corey Prashker in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2012, 12:13 PM
  3. Acceleration issues 2006 Grand Prix
    By Natta in forum General Tech Discussion
    Last Post: 02-15-2012, 10:31 AM
  4. New acceleration vid
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 11-29-2010, 01:58 PM
  5. Pop on acceleration
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2008, 07:07 AM
