Thread: XPZ/Intense Stage 4 Heads
Results 1 to 20 of 27
  1. #1 XPZ/Intense Stage 4 Heads
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Wanted to get opinions if the Intense Stage 4 heads are too much to be ran with a XPZ cam or just fine for it and if i can run those heads without a problem with the XPZ cam. Most likely i will be going with a L36 block and a pretty decent build aiming for close to 400 if possible with the build. But before i spend the money i wanted to get opinions on them since i have been holding off the heads for a pretty long time now and i want to get the build started. so feel free to inform me
  2. #2 Re: XPZ/Intense Stage 4 Heads
    I'd opt for ZZP heads over intense based on exhaust valve size.
    Regardless, 150# springs on intake and 130 on exhaust would be nice if you planned on spinning to 7000 and running 13-16 PSI.
    However do you really?
    If not, 130 intake and 105 exhaust is fine.
    Honestly making more than 350 WHP is really "super secret" as far as GPF knows. We don't make power over here, we just solve common issues and suggest 3.4 setups haha.
  3. #3 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Haha well mainly going with these because of price a used set with less then 3k on them for almost half the cost. and i figure might as well be a bit more ported then not enough.
    Well anything really above 350 ill be happy i know it isnt easy and i dont want to set my expectations to high but around that 350 ill be happy that way if its anything above that ill be surprised lol
  4. #4 Re: XPZ/Intense Stage 4 Heads
    Ohio
    or if you dont wanna dump more money than needed and be limited too 400 wheel...go turbo for less and make way more power
  5. #5 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Quote Originally Posted by 99pgpgt View Post
    Turbo at the moment isnt in my thought never messed with a turbo before and dont know **** about them..
  6. #6 Re: XPZ/Intense Stage 4 Heads
    350 hp and 350whp are very different and as others have said 350 whp on a SC setup is kind of like finding a unicorn or something. IS4 heads and XPZ cam sound like a solid start to me esp if you can get the heads for a good price.
  7. #7 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Well all I really need left is heads and Trans an of course tune but I have a list of parts that I have already.
    So stage 4 heads from intense should be good enough?
    SE Level Member twiztid's Avatar
    Apr 2012
    Fort Wayne, IN
    Quote Originally Posted by GTP89 View Post
    Check out the install instructions on ZZP's website for their turbo setup. The simplicity of it combined with the potential power is hard to ignore if you want those kind of numbers.
    Sent from my Galaxy using Tapatalk 2
    Bryan
    2003 Regal GSX: 54k miles, TOG's, VS Cam, Gen V, HVTB
    2004 Regal LS: 75k miles, For Sale!
    1999 Regal GSX 12.86@108 - sold
  9. #9 Re: XPZ/Intense Stage 4 Heads
    Ohio
  10. #10 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    I might concider it at one point but due to the fact of living in Cali it's hard to get away with a turbo. If I didn't have to worry about it here I would of gone straight turbo and done my research on it by now.
  11. #11 Re: XPZ/Intense Stage 4 Heads
    Jan 2012
    Philadelphia
    if your gonna run intense stage 4 heads you might as well run the intense stage 4 cam too
  12. #12 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Between the xpz and intense stage 4 cam what gives more power?
  13. #13 Re: XPZ/Intense Stage 4 Heads
    Jan 2012
    Philadelphia
    not too sure but this car has a stage 4 intense cam and it sounds nice, and a stage 4 cam is cheaper then an xpz
  14. #14 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Quote Originally Posted by gtpeddie View Post
    Damn thats nice right there
    Stage four is for larger power adders.
    Stage three and xpz are comparable with more top end with the s3 and more midrange with the xpz.
  16. #16 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Well I think for now I will keep the xpz since I have it already :/
    wish I would of known the intense stage 4 would be better. But hopefully I'll be happy with the xpz I mean it isn't a weak cam either.
    You have a larger power adder than the m90?
  18. #18 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Nope but I'm sure maxing out a gen v is good enough for a stage 4 can don't you think?
  19. #19 Re: XPZ/Intense Stage 4 Heads
    Feb 2009
    flintnasty MI
    xpz has been used in all of the record setting 3800 cars just about.
  20. #20 Re: XPZ/Intense Stage 4 Heads
    Jan 2012
    Philadelphia
    there's nothing wrong with the XPZ cam,i was just saying there was more options. i didn't know you had the XPZ already.
  1. Intense Stage 3 Cam and S3 heads as a Daily Driver?
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2011, 06:18 AM
  2. intense stage 3 cam
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2009, 11:27 PM
  3. Intense Stage 2 cam
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2008, 10:32 AM
  4. intense stage 3 cam
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2008, 01:23 AM
