Thread: XPZ/Intense Stage 4 Heads
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: XPZ/Intense Stage 4 Heads
    XPZ is smaller than the S3 and S4 and holds the current M90 record.
    So you tell me.
  2. #22 Re: XPZ/Intense Stage 4 Heads
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Yeah have the xpz reason I went with it is because as stated above by Darkhorizon it's on top of the list for best powered gp on supercharged setups.
    It wasn't cheap but I'm hoping the stage 4 heads will be a perfect fit for the xpz that's why. All I really need is major stuff heads Trans some harness/adapters for a swap and a tune that's about it.
    beaides that I have everything as far as I know.
  3. #23 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    So you tell me.
    So saying I went the right route by going XPZ?
  4. #24 Re: XPZ/Intense Stage 4 Heads
    Yes.
    If you can get a deal on S4 heads, they'll work very well with this cam.
    You'll want ZZP headers for their larger primaries. But you're in CA, so TOGs is your only option there.
  5. #25 Re: XPZ/Intense Stage 4 Heads
    Jan 2012
    Philadelphia
    you could always weld in a cat
  6. #26 Re: XPZ/Intense Stage 4 Heads
    It would have to have a CARB approval number for his specific vehicle on it though.
  7. #27 Re: XPZ/Intense Stage 4 Heads
    Buena Park Ca
    Correct but at 900 bucks Because of a sticker I need ima hold off on it.
    I have a carb number already from a friend that also lives in Cali for tog headers but I will be running my speed daddy's and just have the sticker on the car they won't know the difference.
  1. Intense Stage 3 Cam and S3 heads as a Daily Driver?
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2011, 06:18 AM
  2. intense stage 3 cam
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2009, 11:27 PM
  3. Intense Stage 2 cam
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2008, 10:32 AM
  4. intense stage 3 cam
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2008, 01:23 AM
