Thread: Speed Daddy Headers - quick few questions before I pull the trigger
Results 1 to 20 of 28
Threaded View
  1. #13
    Quote Originally Posted by thomas mcnulty View Post
    sd headers are designed for the egr.
    Not really.
    Quote Originally Posted by gtpeddie View Post
    what if you buy headers with no EGR application?
    Then you don't use EGR?
    All of the questions have been answered numerous times.
    Quote Originally Posted by Elite6 View Post
    I would have to keep the EGR setup as we have emissions testing in Ontario. I am wondering if I should do the install with some upgraded band clamps, wait for the flex to take a crap then have a new flex welded on and u bend deleted? Once the headers are installed does welding a new flex & deleting the u bend required the rear manifold to be removed?
    Since you're in ontario, you need a real cat.
    Between the cat ($200), headers ($280 by the time they get to your door), clamps and RTV ($40), new flex ($50),
    You could have bought a nice set of headers.
    Also don't need an EGR to pass an E-test.
    Leave your engine cover on and they'll never think to check.
    Did you drop the subframe at all or everything through the top?
    As per the many other threads on the same topic: Remove trans dip stick and enjoy.
  1. Speed Daddy headers
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-04-2013, 09:26 AM
  2. Speed Daddy Headers on
    By Deathwish99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2011, 10:40 AM
  3. speed daddy headers
    By PONTIACGTP05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:54 PM
  4. Speed Daddy Headers
    By Advan22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 12:06 AM
