Thread: Can I use AC Delco Engine Sealant for LIM job?
Results 1 to 5 of 5
  1. #1 Can I use AC Delco Engine Sealant for LIM job?
    Cambridge, Ontario Canada
    Last time I did this I used a black sealant I had at home and all was leak free. This time I ordered from ZZP - AC Delco Engine Sealant (light gray colour). Anyone confirm this is ok stuff to use?
    2005 E55 - stock
    Is it rtv? Namely the stuff used by late models for oil pan gasket and front cover gasket?
    If so its good for that application.
  3. #3 Re: Can I use AC Delco Engine Sealant for LIM job?
    Doesn't say anything but engine sealant part 88864346 - does say it has ingredients that are known to cause cancer!! wtf unless most sealants do?
    2005 E55 - stock
  4. #4 Re: Can I use AC Delco Engine Sealant for LIM job?
    rtv according to acdelco.com
    2005 E55 - stock
  5. #5 Re: Can I use AC Delco Engine Sealant for LIM job?
    St. Louis
    I used the Delco gray sealant on my LIM job and it's been just fine. Got it at the dealer. And yes, most sealants, solvents, oils, etc. are known to cause cancer. This is for long periods of time and exposure (cumulative effect). Just wash your hands good after or use some latex gloves and call it good.
  1. Thermostat housing sealant?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 01:02 AM
  2. What Sealant for rotor pack and snout?
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2011, 04:37 PM
  3. sealant for corners?
    By rambo33 in forum Visual/Body Modifications
    Last Post: 10-10-2009, 02:11 PM
  4. use RTV/sealant on UIM?
    By Warbeaver in forum General Tech Discussion
    Last Post: 04-16-2009, 08:29 AM
  5. M90 PCV cover sealant?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-16-2008, 02:54 PM
