Thread: L67 mild mods
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 142
  1. #121 Re: L67 mild mods
    How does an tuned PCM fix KR?
    Because.
    It does.
    If Stock tune or canned PCM is setup for "X" mods but you've got "X" mods + "2.0 dealywhopper"...then you need to tailor the PCM to it.
    C'maaan guy.
  2. #122 Re: L67 mild mods
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    ARE YOU SERIOUS?????? Do you know what DETONATION is? Knock Retard (KR) is just a result of detonation. By adding fuel you compensate for the added boost the calibrated MAP sees. This is what the tuned PCM does. Im done before I get banned from here.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  3. #123 Re: L67 mild mods
    PCM doesnt use MAP unless the MAF has failed.
    If the MAF sees more air and the fuel and air models are correct, the PCM will know it needs more fuel and deliver the correct amount of fuel.
  4. #124 Re: L67 mild mods
    Quote Originally Posted by t24moore View Post
    No brutha.
    I see where you're coming from.
    There is just only so much fuel you can add to where either the pulley drop becomes too much for the car and you need to toss on a larger size...OR...get more flow mods on it.
    Which is why I've always been a fan of a larger pullied, leaner, higher timing car...than a richer, stock~ish tabled timing car on a smaller pulley.
  5. #125 Re: L67 mild mods
    Feb 2008
    Houston
    So you know this but dont know how a PCM can fix KR?? Wow.......and the PCM does use the MAP. If the MAF fails then the car runs off of a VE table. Its amazing you guys give advice but dont know what youre talking about.
  6. #126 Re: L67 mild mods
    Fuel and air calibrations are a tad specific to the engine and I clearly stated the MAP is used in MAF failure.
    So again, how does a canned PCM kill knock other than drowning it in fuel?
  7. #127 Re: L67 mild mods
    Feb 2008
    Houston
    No brutha.
    I understand this, thats why I feel starting with a 3.5 would be optimal with those mods and scan scan scan. People do get pulley envy. Ive personally seen people run faster by pulleying up and adding more timing. Its just that back in the day may of us ran 3.4s with zero issues with the mods that I have listed. The OP even said it himself that over at 3800 pro they have told him the same thing. What makes this site different outside of a lot of newer people here who dont know what they are talking about.
  8. #128 Re: L67 mild mods
    Feb 2008
    Houston
    Look man learn what detonation is. If you add air you must add fuel! How is that drowning it in fuel? When you pulley down the car will run leaner plain and simple. And the VE table is used when MAF values are not present. Do you know the difference between the two sensors???
  9. #129 Re: L67 mild mods
    new britain, ct
    but if you keep adding fuel until it becomes TOO rich then its pointless to even run the smaller pulley. because by that time you are robbing potential power, instead of just running it more lean on a bigger pulley.
    07 Black GXP.
  10. #130 Re: L67 mild mods
    Out West
    Drowning in fuel bogs the car down making it slower than running a bigger pulley leaner.
    Whine with your Cheese?
  11. #131 Re: L67 mild mods
    Does a vehicle that is tuned in the spring or fall run leaner in the summer and richer in the fall?
  12. #132 Re: L67 mild mods
    That last part is a 110% truth.
    The community is full of 16~ year olds who just want more boost.
    It's the luxury Honda forums is what we got here.
    I did that back in the day too, when running 160*'s, PEM's, Race pellets/gas, AL103's were the cool thing to do. It worked then...but there are just more level headed ways to go about it now, IMO.
  13. #133 Re: L67 mild mods
    Feb 2008
    Houston
    I give up, clearly you guys dont know what youre talking about. I can see if I was telling the guy to run a 3.3. But he should have no issue running a 3.5. Im a fan of timing over boost myself.
  14. #134 Re: L67 mild mods
    Out West
    Clearly you're trolling.
  15. #135 Re: L67 mild mods
    Feb 2008
    Houston
    No I dont troll. Thats for kids, im 30 years old and dont have time for that garbage. And now you all are talking garbage in the chatbox? LOL this site is just as bad as GPONA.
  16. #136 Re: L67 mild mods
    Out West
    Then pack it up mister, because you're just going against the grain here.
  17. #137 Re: L67 mild mods
    Feb 2008
    Houston
    LOL I go where I please. Build something better than a rockered 3.2 then come talk to me kid.
  18. #138 Re: L67 mild mods
    You've yet to answer any of my questions and just say I'm wrong.
    How is that any better?
  19. #139 Re: L67 mild mods
    Out West
    I'll build what i please. Mod smarter, Not harder.
  20. #140 Re: L67 mild mods
    Topeka, KS
    Why is this stupid thread still alive?
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. A few new mods...take a look!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 04-05-2010, 12:39 AM
  3. l36 mods want to get into the 14s
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2010, 12:38 AM
  4. ZZP PCM and other mods
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 03:39 PM
