I ended up replacing the ignition harness again which has solved the can't remove key or shift from park issue but now when you turn the key off, if you open the door, the "dinger" is not working. It comes on if you move the ignition switch just a bit to on or access. but won't come on in the off position with the door open.
Is it possible to get the key cylinder out of position a bit on reinstall to cause this? Could this be another ignition harness issue? Everything else is working fine.
Thanks again.
