Thread: Best place to buy Engine Gaskets / Cam Install kits?
Results 1 to 7 of 7
  1. #1 Best place to buy Engine Gaskets / Cam Install kits?
    Topeka, KS
    Best place to buy Engine Gaskets / Cam Install kits? I bought a block last month and am trying to work on buying the stuff to build it. I picked up a stock timing chain and dampener for $35 this week shipped. I just found this and wondered if it was a good deal or not. Genuine GM Cam Installation Kit: 3800 Performance
    I'm not ready to buy hard parts yet but I'll get there when I can. The gasket's i'd like to purchase next and then I'll start working on buying the big stuff.
  2. #2 Re: Best place to buy Engine Gaskets / Cam Install kits?
    I'd say piece things together. Use discount codes online with Advance or whatever local parts places you have.
    The kit you referenced has plastic LIM's, no valve cover grommets and stock rocker bolts.
    Personally I like a good happy set of Fel Pro VC's with the grommets, GM LIM's or Fel Pro, set of reusable rocker bolts, Fel Pro viton valve seals, front cover gasket or a lower conversion kit. The lower conversion kit is the cheaper way to get a pile of gaskets including an oil pan gasket for less than buying the oil pan gasket alone.
  3. #3 Re: Best place to buy Engine Gaskets / Cam Install kits?
    Topeka, KS
    Lower conversion kit ? Is that a gm kit of some sort ?
  4. #4 Re: Best place to buy Engine Gaskets / Cam Install kits?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by rynoman03 View Post
    All gaskets below heads.
    http://www.rockauto.com/getimage/get...CS9917_TOP.jpg
  5. #5 Re: Best place to buy Engine Gaskets / Cam Install kits?
    Topeka, KS
    Interesting. I'll have to look into this.
  6. #6 Re: Best place to buy Engine Gaskets / Cam Install kits?
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    im with bill
  7. #7 Re: Best place to buy Engine Gaskets / Cam Install kits?
    Topeka, KS
    Sounds good. I'll probably start with the lower conversion kit. Anyone got a link to it on RockAuto?
  1. engine install?
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2011, 01:27 PM
  2. Engine install cost
    By rotti3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2011, 10:30 AM
  3. engine rebuilt kits
    By yellow600r in forum General Tech Discussion
    Last Post: 12-19-2010, 11:21 AM
  4. Can I install eaton m62 supercharger on L36 engine?
    By SBB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 01:15 PM
  5. Trimming Gen 5 gaskets for IC install
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2008, 03:12 PM
