Thread: Can't remove key or shift from park
Results 1 to 6 of 6
  1. #1 Re: Can't remove key or shift from park
    May 2012
    Indiana, PA
    shift from park, i'd usually start looking at the brake pedal.
  2. #2 Re: Can't remove key or shift from park
    Thanks Chrisatpsu,
    Just got the car in the garage and noticed the shift indicator on the dash is not working either.
    Still won't release the key or shift from park unless I release them manually. I'm going to replace the harness with the old one to see if that is the issue especially with the indicator not working and I'll check that brake switch while I'm in there.
    Thanks for the reply.
    I'll definitly post the solution when I get it.
  1. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  2. my car wont shift from park without pressing relese button
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-12-2012, 12:49 AM
  3. Shift from park to reverse or drive, quick question
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2011, 04:20 PM
  4. Won't Shift Out of Park (sometimes)... Ignition Switch?
    By GTFiske in forum General Tech Discussion
    Last Post: 01-12-2011, 12:53 PM
  5. Where do you park.....
    By SiDeWaYz in forum Off Topic Discussion
    Last Post: 06-13-2010, 09:34 AM
