Thread: Help with Supercharger Noise
Results 1 to 7 of 7
  1. #1 Help with Supercharger Noise
    Banned
    Sioux Falls, SD
    Its hard to catch the sound on the camera, but it sounds like a scratching sound here the video Its the gf's car it has 100K on the clock the s/c oil was change about 5K ago when i did the LIM
    2012-06-04_17-25-37_276.mp4 video by Pontiac_gtp - Photobucket
    Dec 2010
    DMV
    Is it more like rocks rattling around? If so the coupler is bad.
  3. #3 Re: Help with Supercharger Noise
    Florida
    Can you hear it better from the snout, or the intake?
    It sounds like either something fell into the snout when you changed the oil (a little pebble or something) or some of the coating on the rotors is shot.
    Though hopefully a more trained ear will chime in.
  4. #4 Re: Help with Supercharger Noise
    Banned
    Sioux Falls, SD
    When i used my steoscope its coming from the snout, and when i changed the oil, I dont think anything could of fell in there cause it was off the car. The coating on the rotors were in GREAT shape
  5. #5 Re: Help with Supercharger Noise
    Florida
    In that case, a bad bearing in the snout.
  6. #6 Re: Help with Supercharger Noise
    Banned
    Sioux Falls, SD
    Hopefully it is, its under a warranty with no deductable, probally will end up getting a used one
  7. #7 Re: Help with Supercharger Noise
    I live here. TLSheff's Avatar
    Fast check. Take the belt off. Rock the pulley(by hand) back and forth, if it feels a little loose between shakes then the couple is worn, 100k on a stock coupler is about the breaking point.
    If it feels tight and there is NO play in it, spin it fully and see if you can feel a odd spot (should have a rough spot if the bearing are going).
    This is the best way to check for sure and it will only cost you about 20-30 mins max.
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. Supercharger Noise
    By Jbruce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 09:41 PM
  3. noise from supercharger
    By johndoe35652 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 02:22 AM
  4. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
  5. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
