Ok so im chasing down a problem and im clueless right now with it. Under wot right at about shift my car will pop/blow air and will kick up about 6.5 knock on my scan gauge and u feal a noticeable loss of power and the car takes a sec to recover. I also noticed that my valve cover gaskets are both leaking pretty good(idk if that has anything to do with it a friend said it might be to much crankcase pressure) my current mods are zzp fullsize intercooler, ported lim/sc, speed daddy headers no cat or res and magnaflow mufflers, 1.9 modded rockers, zzp1.0 pcm, and a 3.1 pulley. Idk if the pcv could be bad causing this not venting the crank or burst kr(which im still learning wut it is) or wtf, any help is appreciated thanks
