Thread: EGR valve on a 1998 GTP
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: EGR valve on a 1998 GTP
    Dec 2011
    chicago
    I upgraded to a zzp computer and they can actually delete all evap and egr codes from the reflash pcm.
  2. #22 Re: EGR valve on a 1998 GTP
    Mar 2012
    lakewood
    Correct me if I'm wrong, doesn't egr also help reduce knock?
  3. #23 Re: EGR valve on a 1998 GTP
    ^^^^ not really no...
  4. #24 Re: EGR valve on a 1998 GTP
    Mar 2012
    lakewood
    Pretty sure it does, it reduces nox and lowers combustion chamber temps.
    Exhaust gas recirculation - Wikipedia, the free encyclopedia
  5. #25 Re: EGR valve on a 1998 GTP
    GT Level Member ShadowSwept's Avatar
    Kentucky
    By pumping dirty exhaust gasses into your engine and eventually clogging things up and causing more trouble than it's worth.
    You'd be better off with a meth or water injection if your concerned about that.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  6. #26 Re: EGR valve on a 1998 GTP
    Quote Originally Posted by thomas mcnulty View Post
    it MIGHT help for cruising knock (which can be fixed easily with a tune with or without an EGR) but its not gonna help with knock because the valve is closed when most have knock issues anyway...
    The Boss Iceman6669's Avatar
    Jun 2011
    Why would someone want to pump Hot gases into the intake when we are all trying to LOWER intake temps??
    2011 F-150 Yote powered
  8. #28 Re: EGR valve on a 1998 GTP
    egr does lower combustion temps.
    ice, egr post TB, intake temps have nothing to do with it.
  9. #29 Re: EGR valve on a 1998 GTP
    Mar 2012
    lakewood
    If one were concerned with intake temps, maybe the l67 is not right for you
  1. New guy, 1998 GT
    By harner in forum Introductions/Noob Questions
    Last Post: 04-15-2012, 10:20 AM
  2. 1998 gtp
    By iQuallzey in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2010, 11:21 PM
