Thread: EGR valve on a 1998 GTP
Results 1 to 20 of 29
  1. #1 EGR valve on a 1998 GTP
    Apr 2012
    Mattawan, MI
    my EGR valve is shot....But the problem is i cannot find it anywhere. It is know that they are behind the throttle body, I have seen pictures and i still cannot locate it, Here is a picture..if you can help me locate it that would be greatly appreciated.2012-05-26 14.48.14.jpg
  2. #2 Re: EGR valve on a 1998 GTP
    The Boss Iceman6669's Avatar
    Jun 2011
    ok man your pic didnt work for me...
    This is where it should be.
    Ok it should be right in front of the Tranny Fluid Dip stick. Inside that little shield thing.
    2011 F-150 Yote powered
  3. #3 Re: EGR valve on a 1998 GTP
    Ohio
    its on the driver side of the rear valve cover. its raised up abit,
  4. #4 Re: EGR valve on a 1998 GTP
    Apr 2012
    Mattawan, MI
    There is nothing in front of the tranny dip stick.. its a open gap. if you right click on the picture and open it in a new window it will work.
  5. #5 Re: EGR valve on a 1998 GTP
    Jun 2011
    I still can not get your pic to work.. BUT if you look at my second pic. The little shield thing in front of the tranny dip stick. That is where the EGR SHOULD be. Mine has been deleted...
  6. #6 Re: EGR valve on a 1998 GTP
    Apr 2012
    Mattawan, MI
  7. #7 Re: EGR valve on a 1998 GTP
    Grand Island, Nebraska
    find your rear exhaust manifold. There should be a little tube that comes out the the tube on the diver-most side. follow that to the EGR. If its blocked off, you dont have it.
  8. #8 Re: EGR valve on a 1998 GTP
    Florida
    Ok just found this pic. the engine is being seen from the driver side of the engine bay. the shield shown lifted is the EGR shield. that thing that looks like half of a can of Beer/ soda is the EGR.
  9. #9 Re: EGR valve on a 1998 GTP
    Apr 2012
    Mattawan, MI
    I dont think i have one because there is nothing there and the connector for it is just lying there(not plugged into anything) how do i approach this. is it because i have custom headers? How do i put one in there if there is no where to connect it to...as shown in the picture above.
  10. #10 Re: EGR valve on a 1998 GTP
    Mar 2012
    NC
    Have someone tune it out. Or find a way to add it back in. The first option being probably the best choice.
  11. #11 Re: EGR valve on a 1998 GTP
    Apr 2012
    Mattawan, MI
    Alright thanks man
  12. #12 Re: EGR valve on a 1998 GTP
    odds are if there are aftermarket headers on there it has been yanked...
  13. #13 Re: EGR valve on a 1998 GTP
    Apr 2012
    canada
    Hello . I saw a mod you did to the EGR. Is it a bolt welded in to disable it. I want mine disabled. Thanks
  14. #14 Re: EGR valve on a 1998 GTP
    Florida
    physically removing it is the easy part. you need to have the codes disabled in the pcm for it.
  15. #15 Re: EGR valve on a 1998 GTP
    Apr 2012
    canada
    I am wondering how you plugged the port into the manifold? Is it a big issue to clear the codes and what happens if the codes are not cleared? Thanks
  16. #16 Re: EGR valve on a 1998 GTP
    Mar 2012
    lakewood
    What is the benefit of deleting it
  17. #17 Re: EGR valve on a 1998 GTP
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Quote Originally Posted by thomas mcnulty View Post
    It won't be pumping exhaust back into your engine and gunking everything up.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
    Jun 2011
    Quote Originally Posted by flyerboy101 View Post
    If you are talking to me.... Then yes I shoved bolts into the tubes and welded it closed. Not the best way to do it but it works.
  19. #19 Re: EGR valve on a 1998 GTP
    Willoughby, Ohio
    egr delete=win mmm fresh air
    Bunnell, FL
    I have the zzp plates
    I'm a Sex Offender
  1. New guy, 1998 GT
    By harner in forum Introductions/Noob Questions
    Last Post: 04-15-2012, 10:20 AM
  2. 1998 gtp
    By iQuallzey in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2010, 11:21 PM
