Thread: coolant on spark plugs
Results 1 to 20 of 31
  1. #1 coolant on spark plugs
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    Removed spark plugs and on cylinder 3 I notice it had coolant on it haven't removed the rear one but I'm assuming that they will have coolant too will thus be case with the head gasket or the lower intake gasket
  2. #2 Re: coolant on spark plugs
    intake.
    HG are so rare to go bad.
  3. #3 Re: coolant on spark plugs
    May 2011
    El paso tx
    That's what I thought that it would be the intake but wasn't sure because I don't have my oil milky
  4. #4 Re: coolant on spark plugs
    This is commonly a gasket in the intake tract. Meaning this can be a throttle body gasket, a supercharger to LIM gasket or a LIM gasket. Likely though..I'd put high odds on the first two.
    And if you have a TB spacer...well we know right where the leak is.
  5. #5 Re: coolant on spark plugs
    May 2011
    El paso tx
    Nope I don't have a tb spacer I'm all stock just an intake. I'm gonna change the lim gasket supercharger gasket and tb and ill go from there.
  6. #6 Re: coolant on spark plugs
    I'd suggest pulling the TB first. Look into the SC and if it's soaked, then most likely it was the tb gasket. Then pull the SC and if the gasket is soaked, it was the SC gasket. It's just the fact that it's tough for the LIM gasket to leak that much into the cylinders.
  7. #7 Re: coolant on spark plugs
    May 2011
    El paso tx
    Ok I will do that asap and it can't be the head gasket right
  8. #8 Re: coolant on spark plugs
    Chances are extremely slim
  9. #9 Re: coolant on spark plugs
    May 2011
    El paso tx
    Thanks bill for the info ill follow those steps and ill update asap I figure what went wrong appreciate your help
  10. #10 Re: coolant on spark plugs
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    your saying all TB spacers leak?
    my car already had one, when i purchased. Is there any real benefit to the spacer? you need two tb gaskets for the spacer to SC and TB to spacer?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  11. #11 Re: coolant on spark plugs
    Donating Users crock's Avatar
    Traverse City, Michigan
    The benefit on a spacer on a GTP isn't much. The spacer is used for a chance for the air to cool down more when entering the intake. But, on GTP's the air is only going to warm back up when going through the supercharger. Not all of them leak, but they have a greater possibility of leaking. More gaskets=more leaking possibilities. Someone correct me if im wrong...
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  12. #12 Re: coolant on spark plugs
    May 2011
    El paso tx
    ^x2
  13. #13 Re: coolant on spark plugs
    Crock is on the money. Plus I think that often the spacers from ZZP shipped with Garleak (aka gonna leak) gaskets.
  14. #14 Re: coolant on spark plugs
    Mar 2012
    Dallas
    looks like i will be removing mine this weekend.
    thanks.
    do i need to drain the coolant to remove the TB?
  15. #15 Re: coolant on spark plugs
    May 2011
    El paso tx
    Where can I get the gasket from the supercharger to the lim AutoZone and oreilly don't carry it? Don't want want to wait that long for shipping
  16. #16 Re: coolant on spark plugs
    they carry them.
    Its just called a upper intake gasket for the L67
  17. #17 Re: coolant on spark plugs
    May 2011
    El paso tx
    Oh ok I will verify that tomorrow thanks
  18. #18 Re: coolant on spark plugs
    Tampa
    I may have a similar problem. White smoke had come from my passenger side. I had it towed. I was told that I needed to replace my water pump, radiator, thermostat, and hoses. I replaced all of them and when I went to flush the system, I detected leaking. It wasn't too apparent where it was leaking from. A puddle formed just underneath the oil pan. When I went to drain the water, I could hear a hissing sound coming from just above the water pump but below the supercharger. Any thoughts?
  19. #19 Re: coolant on spark plugs
    Quote Originally Posted by USF3983 View Post
    could be a cracked coolant elbow.
  20. #20 Re: coolant on spark plugs
    Tampa
    Yeah I've been reading about that. I guess I should check that out first.
  1. please help with spark plugs!!
    By asite57 in forum General Tech Discussion
    Last Post: 02-24-2012, 07:16 PM
  2. Which Spark Plugs Should I Run?!?
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2011, 08:27 PM
  3. Spark plugs, etc.
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2010, 06:52 PM
  4. 5.3L V8 Spark Plugs
    By 06usafgxp in forum General Tech Discussion
    Last Post: 01-29-2010, 09:23 PM
  5. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
