Thread: coolant on spark plugs
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: coolant on spark plugs
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    I replace everything today now the car car won't start I have a big leak of fuel on number 6 injector its not sealing right and can remember how ask the vacuum hoses go
  2. #22 Re: coolant on spark plugs
    Tampa
    I replaced the coolant elbows and it seems to have stopped leaking as much as it was before, but it seems to still be leaking a little bit. My hoses flattened and I looked up what that possibly might be. The leaking is coming from the back but I can't tell if its originating from somewhere else. The rear coolant elbow at the purple o-ring going into the water pump didn't seem to go in as far as I thought it would. Should the back edge on the outer side of the purple o-ring stick outside of the water pump a little bit? It doesn't seem to be leaking at that point.
    Would the hoses get sucked in and flatten if there was a leak to worry about?
  3. #23 Re: coolant on spark plugs
    Hoses flattening is usually a sign of a bad radiator cap.
    On the elbow.. the elbow sticking out or the o-ring. The edge of the elbow should..not the o-ring.
  4. #24 Re: coolant on spark plugs
    Tampa
    Nah, the o-ring is not exposed. Just the raised portion sticks out a bit. The ends inserted into the tensioner/heater hoses get jammed way in there. I guess thats due to the flow coming from that way. If that's correct. I'm not even sure of which way the coolant flows. Is it coming from the heater hoses to the manifold and water pump?
    Yeah I figured the cap could be a problem. It looks like a newer cap, but I let the dexcool get all crusted up on the interior of the cap. I'll try that next.
    Thanks.
  5. #25 Re: coolant on spark plugs
    Tampa
    Ok, so far it looks like a new radiator cap fixed the problem. So far no flattened hoses. I did notice that the alternator wasn't spinning while I was letting the car get up to temp. Is that normal?
  6. #26 Re: coolant on spark plugs
    Quote Originally Posted by USF3983 View Post
    thats impossible. you sure you looking at the alt?
  7. #27 Re: coolant on spark plugs
    Tampa
    Yeah, I had it off earlier and it was spinning with the pulley. I didn't torque it down to spec since I was going anywhere with the car, but I figured if the belt was on the pulley the alternator should be spinning.
  8. #28 Re: coolant on spark plugs
    make sure your belt is on right, it should be quite tight, and nothing should be free wheeling at all, or not spinning.
  9. #29 Re: coolant on spark plugs
    Tampa
    I'm an idiot. lol. It's spinning. I was thinking the outer shell of red wiring was supposed to be moving. The inner part underneath IS spinning.
  10. #30 Re: coolant on spark plugs
    May 2011
    El paso tx
    I fix the gas leak and nite that put together everything car won't start it backfires from tb check everything and it looks fine
  11. #31 Re: coolant on spark plugs
    May 2011
    El paso tx
    Removed the head because it was still having coolant on spark plugs after changed the lim, supercharger, tb gasket and found this on the heads Mobile Photobucket
  1. please help with spark plugs!!
    By asite57 in forum General Tech Discussion
    Last Post: 02-24-2012, 07:16 PM
  2. Which Spark Plugs Should I Run?!?
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2011, 08:27 PM
  3. Spark plugs, etc.
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2010, 06:52 PM
  4. 5.3L V8 Spark Plugs
    By 06usafgxp in forum General Tech Discussion
    Last Post: 01-29-2010, 09:23 PM
  5. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
