Im wanting to have this put on before my dyno in June. Also what pulley size can you drop to. My Setup is Xp Cam, 105 Springs, Double Chain, 42.5 Lucas injectors, Headers, and currently a 3.4 MPS.
Intercooler core:
http://www.grandprixforums.net/pheno...ler-42711.html
Heat Exchanger: (not sure what thickness to go with)Air to Water Radiator
Or
Air to Water Heat Exchanger
Modded Fuel Rail: I wanna make these myself, if anyone has any ideas, I was thinking about a flare tool and some fittings then some braided stainless steel line that goes from one side to the other.
ZZPerformance - Modified Fuel Rails #ZZ-MODFR
Bosch Pump:
Bosch - Bosch Intercooler Pump #BSH-0392022002-IC
Intercooler Hoses:
Local hardware store. Anyone have a idea how man feet i need of hose?
Intercooler Fill:
Intercooler Fill/ Reservoir kit
Anything im missing?
Can i use the stock S/C gasket that is for the Gen V? its the metal one? if not what gaskets do i use?
