Thread: L32 Intercooler Setup.......Need some advice
Results 1 to 13 of 13
  1. #1 L32 Intercooler Setup.......Need some advice
    Banned
    Sioux Falls, SD
    Im wanting to have this put on before my dyno in June. Also what pulley size can you drop to. My Setup is Xp Cam, 105 Springs, Double Chain, 42.5 Lucas injectors, Headers, and currently a 3.4 MPS.
    Intercooler core:
    http://www.grandprixforums.net/pheno...ler-42711.html
    Heat Exchanger: (not sure what thickness to go with)Air to Water Radiator
    Or
    Air to Water Heat Exchanger
    Modded Fuel Rail: I wanna make these myself, if anyone has any ideas, I was thinking about a flare tool and some fittings then some braided stainless steel line that goes from one side to the other.
    ZZPerformance - Modified Fuel Rails #ZZ-MODFR
    Bosch Pump:
    Bosch - Bosch Intercooler Pump #BSH-0392022002-IC
    Intercooler Hoses:
    Local hardware store. Anyone have a idea how man feet i need of hose?
    Intercooler Fill:
    Intercooler Fill/ Reservoir kit
    Anything im missing?
    Can i use the stock S/C gasket that is for the Gen V? its the metal one? if not what gaskets do i use?
  2. #2 Re: L32 Intercooler Setup.......Need some advice
    You're missing the tune factor.
    And the fact you just can't say I have "X" mods and I want "Y" pulley.
    Keep the 3.4" and start from there.
  3. #3 Re: L32 Intercooler Setup.......Need some advice
    Banned
    Sioux Falls, SD
    I know the tune factor, I just want to know what you can drop to?
  4. #4 Re: L32 Intercooler Setup.......Need some advice
    Every car is different.
    So, until you have it on the scanner looking at what you can get away with knock free on a solid AFR and 16* or more timing at WOT...then a 3.4" should be it anyways.
  5. #5 Re: L32 Intercooler Setup.......Need some advice
    Banned
    Sioux Falls, SD
    Ok thats what i wanted to know
  6. #6 Re: L32 Intercooler Setup.......Need some advice
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    so what your saying is that i can keep droping the pulley as long as it has more then 16* of timming, knock free and a soild AFR?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  7. #7 Re: L32 Intercooler Setup.......Need some advice
    Texas
    42.5 injectors should cover you down to around 3.0 pulley possibly smaller if you get the tune set just right.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: L32 Intercooler Setup.......Need some advice
    Oct 2011
    Michigan
    but youll get worse gas millage
  9. #9 Re: L32 Intercooler Setup.......Need some advice
    Omaha, NE
    More air = More fuel No matter what injector you have.
    The only time there is a noticeable drop in MPGs is on E-85 because it requires ~33% more fuel.
  10. #10 Re: L32 Intercooler Setup.......Need some advice
    Oct 2011
    Michigan
    wait so your saying if i add more air (smaller pulley) and more fuel (bigger injectors) with supporting intake/exhaust mods of course i wont get worse mpgs? as long as i dont drive it harder i mean
  11. #11 Re: L32 Intercooler Setup.......Need some advice
    Quote Originally Posted by asite57 View Post
    Yes.
    I got over 30~ crusing on the highway with 3.29's, my entire top end of the motor was ported, running a ported LS1 TB setup, full exhaust, a 3.0", with a pretty beefy cam and a custom tune via HPT.
  12. #12 Re: L32 Intercooler Setup.......Need some advice
    Oct 2011
    Michigan
    wow thats what im getting now bone stock
  13. #13 Re: L32 Intercooler Setup.......Need some advice
    Jersey
    fwiw i ran a 3.0 on xp cam, and wbs stage II intercooler with a solid 11.5-11.2 afr and 16* of timing on a L36
    16' wrx sti- stock
  1. 3.25 setup
    By ryanmjw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2011, 08:46 AM
  2. Intercooler advice
    By gtpnutz in forum General Tech Discussion
    Last Post: 05-16-2011, 10:06 PM
  3. Twin Screw/ Intercooler setup
    By Rocket468 in forum Off Topic Discussion
    Last Post: 08-08-2010, 02:33 PM
  4. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  5. Replies: 8
    Last Post: 03-22-2009, 01:39 PM
