Thread: Intercooler and pulley size.
Results 1 to 13 of 13
  1. #1 Intercooler and pulley size.
    Chicago
    So right now I have a u-bend delete/104's/FWI/180 stat/3.4" and with 16* I get no KR. If I added an intercooler with just these mods what size pulley should I run? I plan on headers and 1.9's in the future but going to intercool it first. I dont want to order a 3.3 then a 3.2 then a 3.1 so I just want to know where to start. I can tune it myself so if I need I can run a little less timing till I get my headers if needed.
  2. #2 Re: Intercooler and pulley size.
    I get headers before the intercooler. More flow is always better. But after headers and a full size intercooler you could probably run a 3.2 ish but it really depends on the car and the tune.
  3. #3 Re: Intercooler and pulley size.
    Quincy, Mass
    yes headers are a good idea. you should stay on the 3.4 and add more timing.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Intercooler and pulley size.
    GTP Level Member buickman104's Avatar
    NYC
    If you had good exhaust flow and got a full sized intercooler then you would be limited by your fuel injectors and tune.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Intercooler and pulley size.
    what intercooler before I try and answer this...???
  6. #6 Re: Intercooler and pulley size.
    Chicago
    Quote Originally Posted by gtpsleeper View Post
    its a zzp s2ic...thanks so far for the info!
  7. #7 Re: Intercooler and pulley size.
    what psi are you getting (on average) with your current setup...
  8. #8 Re: Intercooler and pulley size.
    this
  9. #9 Re: Intercooler and pulley size.
    Chicago
    On average I see 10-11 psi
  10. #10 Re: Intercooler and pulley size.
    Feb 2009
    flintnasty MI
    3.0 pulley imo... assuming a full sized intercooler and upgraded injectors
    Stock + intercooler is a pretty common setup around here, it works well, you dont need headers and all the other crap people are talking about.
  11. #11 Re: Intercooler and pulley size.
    lol 3.4 on a full size intercooler.
    you people smoke way too much crack.
    Quincy, Mass
    With no headers or valve train mods, Id start out with the 3.4. Definitely wouldn't start on 3.0.
  13. #13 Re: Intercooler and pulley size.
    3.2... MAYBE a 3.1 if youre lucky...
    remember, the intercooler doesn increase flow so to be honest your gains wont be that great right away.... however, when you get around to flow mods it will amplify the gains of them...
    do you NEED more flow? not necessarily... but you wont see the potential of your IC without atleast some rockers and/or headers...
    thats why everyone is telling you to get headers and flow mods...
  1. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  2. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  3. Full Size Intercooler Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:38 AM
  4. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
