Thread: header question
Results 1 to 20 of 25
  1. #1 header question
    Mar 2012
    lakewood
    im not mentally retarted and realize i need my catalytic convertor. i just got my speed daddy header setup and the section (that should be my cat) they sent a straight pipe. i am guessing they give you this section to get by. how long till i have issues with just running the straight insert as opposed to the cat?
  2. #2 Re: header question
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    you dont need a cat unless you have emissions testing in your state, if you have a 97-00 then you can put an O2 sim on your downstream o2 and have no problems if you have a 01+ then you need a tune
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: header question
    Mar 2012
    lakewood
    my emission testing just involves the obd2 test, this is not going to kick off a check engine light?
  4. #4 Re: header question
    Mar 2012
    lakewood
    too easy, 45$
  5. #5 Re: header question
    It'll throw a light but it can be tuned out.
  6. #6 Re: header question
    Oct 2011
    Michigan
    OP what year is your car?
  7. #7 Re: header question
    Mar 2012
    lakewood
    97 gtp, just got done pulling my old setup off. took about 3 1/2 hrs. wasn't hard at all, would have gone faster if i wasn't overly cautious with the bolts.
  8. #8 Re: header question
    Mar 2012
    lakewood
    whats up with the front manifolds on these things.....mine is cracked in 5 places
  9. #9 Re: header question
    because its a cast part.
    yay gm.
  10. #10 Re: header question
    Mar 2012
    lakewood
    what is the downfall of not wrapping the crossover, aside from hotter intake air?
  11. #11 Re: header question
    To me its not worth it to wrap headers on these cars, they heat soak fast and the blower heats the air up anyway.
    So, i'd just leave it.
  12. #12 Re: header question
    Mar 2012
    lakewood
    and roger
  13. #13 Re: header question
    Oct 2011
    Michigan
    you can out an O2 sim in place of the rear O2 and run it with no cat it will not trow a code
    Easy Performance - O2 Emulator #EP-O2SM-GM01
  14. #14 Re: header question
    O2 sim or have it tuned out, or put a cheap high flow in place.
  15. #15 Re: header question
    Quincy, Mass
    even the high flow cats can set a light, it did for me when i had a 3" dp. i had no problems passing the obd test with the o2 sim and i have no problems now with it tuned out.
    No more GP 04 Impala SS Indy:
  16. #16 Re: header question
    He's a 97 though. They were extremely lenient in 97.
  17. #17 Re: header question
    Quincy, Mass
    lucky bastard
  18. #18 Re: header question
    Yup... 97 was a sweet year for a few things.
  19. #19 Re: header question
    Oct 2011
    Michigan
    but a disappointing thing for others 99 was the best year! (of that body style)
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Yay me!! 97 ftw!
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  1. Header question
    By Logan541 in forum General Tech Discussion
    Last Post: 11-12-2011, 07:37 PM
  2. Header question
    By flaspeeder in forum General Tech Discussion
    Last Post: 09-19-2011, 08:21 PM
  3. sd header question
    By m17davis in forum General Tech Discussion
    Last Post: 02-10-2011, 11:28 PM
  4. header question
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 03-06-2010, 09:39 AM
  5. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
