Thread: chirping sound?
Results 1 to 8 of 8
  1. #1 chirping sound?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    only happens on cold start up.
    a chirping sound from the top of the engine, supercharger area. after warmed up, it stops.
    also is it normal for a push rod engine to be so noisy? i use valveline synpower 10w30, full of oil
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: chirping sound?
    Nov 2011
    NY
    Sound goes away when warm? Check pulleys?
    Or better yet, post a sound sample...
  3. #3 Re: chirping sound?
    Mar 2012
    lakewood
    noisy? the supercharger is really noisy...as far as the engine? what kind of noise?
  4. #4 Re: chirping sound?
    Mar 2012
    lakewood
    im assuming your hearing the supercharger
  5. #5 Re: chirping sound?
    Mar 2012
    Dallas
    dont really have a way to record sound. almost a metallic chirping sound.
    it increases in speed with increased rpm.
  6. #6 Re: chirping sound?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    http://www.grandprixforums.net/gtpsh...e-7-57653.html does it sound like the video on the last page
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  7. #7 Re: chirping sound?
    Mar 2012
    Dallas
    is there a way to post a direct sound clip, im on school computers and it wont let me listen to it.
    EDIT: found a vid that has the same chirping noise. and it is not a knocking sound, i listened to both flex plate noise and rod knock, it does not sound like that.
    in this vid its the chirping sound, not the knocking sound
    http://www.youtube.com/watch?v=4kWoOlnPZLY
  8. #8 Re: chirping sound?
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    It's a bearing I'd say. Not sure which, could be tensioner, idler, alternator, etc... It's stopping chirping after the bearing has warmed up and softened a bit. You can find them sometimes by spraying a bit of wd40 on the bearing in question while it's chirping and see if it stops. You could also narrow the possibilities by removing the S/C belt and see if it's still there with it off.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  1. Cricket chirping and other odd noises
    By danielle15 in forum General Tech Discussion
    Last Post: 10-23-2011, 08:03 PM
  2. chirping noise
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-07-2011, 07:13 AM
  3. squeak/chirping noises
    By blight86 in forum Introductions/Noob Questions
    Last Post: 03-15-2011, 03:15 PM
  4. chirping
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-24-2010, 07:07 PM
  5. Chirping Noise
    By TeeWX in forum General Tech Discussion
    Last Post: 09-02-2009, 07:29 PM
