Thread: coolant elbow specs
Results 1 to 20 of 29
  1. #1 coolant elbow specs
    utah
    I need em. Have a friend that owns a metal works shop that's gonna make some in metal. If they end up working he is willing to produce a good sized batch. If they sell he will make more and put them on sale for good.
  2. #2 Re: coolant elbow specs
    Portland Oregon
    I'm in for a few sets!!!
  3. #3 Re: coolant elbow specs
    utah
    He's excited to do em. Just need good spec...and I don't have any laying around.
  4. #4 Re: coolant elbow specs
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by boostedcompg View Post
    Why not just buy a set for him to look at and take perfect measurements as cheap as they are... You can count me in for a set so long as they aren't super expensive, and even if they are I may still buy a set just to ditch these ****ty plastic ones that fail all the time.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  5. #5 Re: coolant elbow specs
    Portland Oregon
    Any oreilly's or autozone should have them in stock
  6. #6 Re: coolant elbow specs
    utah
    He said they'd be around double the price. Which is good imo. Obviously the more he sells the cheaper they get
  7. #7 Re: coolant elbow specs
    PA
    Wow, I would be interested in a set for that price.
    As I said in the other thread, I can see a couple ways of making these, but none that cheap. But hey, what do I know...
    2001 GSE
  8. #8 Re: coolant elbow specs
    I don't think they'd be all that hard to make. With the right equipment. All you have to do is machine the two ends round, put a groove in for the o-ring and drill the 90 degree in them. You could leave the rest as square stock.
    I'm just saying.. I don't have elbow issues.
  9. #9 Re: coolant elbow specs
    PA
    To go that route, you would have to start with rectangle stock and do all the work on a mill, or a lathe with live tooling. Expensive machines. For us, we charge $75/hr for our lathe and mill work. The doesn't include any one time NRE or tooling costs to get things up and running. And because there is two end, you would probably have two setups. Or one setup and turn the part. Still time. I would think a minimum of 20-30 minutes machine time. So just a rough estimate of $50/part that way.
    The route I would go is get tubing, machine each end to the correct diameter with an o-ring groove. This can be done on a manual or cheap little CNC, even a screw machine. Then cut the ends at 45 and weld them together. Simple, quick and done. Probably about $20-25/part.
    But if this guy can get them in under $10, I will buy a set or two. I don't have elbow issues either. But my dad did have issues that one broke as he was driving, lost all coolant, overheated the engine, and warped the heads. So for peace of mind, a metal one would be nice. And $10/ea would be the price point I would buy one.
    2001 GSE
  10. #10 Re: coolant elbow specs
    Panama City Beach, FL
    Quote Originally Posted by sav24dl View Post
    Get a set from GM, there are a little bigger and built better.
    Reason I ask is .. I've used both, compared both side by side and even measured them. They appear identical in all ways. Including o-ring color.
    Failure rate for newbs is pretty much the same too. I haven't had an issue installing one etc in quite a long time.
    Failure rate for newbs? Yeah tell that one that to my mechanic in the states who installed them!
    Myself or Bill I'm sure would be delighted to speak to your mechanic in the states and bounce the phrases Noobsnatch and noob right off him.
  11. #11 Re: coolant elbow specs
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    id be interested in a set for a descent price
  12. #12 Re: coolant elbow specs
    GTP Level Member buickman104's Avatar
    NYC
    I'd be interested in a set too.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  13. #13 Re: coolant elbow specs
    utah
    Stop hurtin feelings on my thread. Cross over the anger bridge and come back to the friendship shores
  14. #14 Re: coolant elbow specs
    Grand Rapids, MI
    i'd be interested in a set as well, i hate those plastic pieces junk.
  15. #15 Re: coolant elbow specs
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Still looking for measurements? I have a set of brand new un-installed Genuine GM ones in my hand..
    PM me if you need measurements..
    I have an accurate vernier at work. I'll even take pics of how and where they are being measured.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  16. #16 Re: coolant elbow specs
    Nov 2008
    norman oklahoma
    i would like a pair for the peace of mind and trick
  17. #17 Re: coolant elbow specs
    Feb 2010
    Oklahoma City, OK
    So what the hell happened to the metal coolant elbows? I'm gonna need a set pretty soon, sure would like them to be metal
  18. #18 Re: coolant elbow specs
    Antioch, IL
    +1 me too I got 12k outta this pair and the intake side is dripping slowly
    2009 Challenger SRT8
    Expert at being gay.
  19. #19 Re: coolant elbow specs
    Portland Oregon
    Updates?
  20. #20 Re: coolant elbow specs
    Jul 2011
    Lancaster, PA
    any news on these? I am in for a set.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  4. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
  5. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
