Thread: I hear a tapping from what I think is on of the valves..
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: I hear a tapping from what I think is on of the valves..
    SE Level Member joelee669's Avatar
    Jan 2012
    manville, nj 08835
    yea flat side is up! LOL how the hell can u manage that, i bought a stethoscope to find out what cylinder it is coming from, then i will go from there
  2. #22 Re: I hear a tapping from what I think is on of the valves..
    Jan 2012
    manville, nj 08835
    ok thanks for the info
  3. #23 Re: I hear a tapping from what I think is on of the valves..
    Would anyone like to hear my sewing machine 3800?
  4. #24 Re: I hear a tapping from what I think is on of the valves..
    Quote Originally Posted by 99pgpgt View Post
    are you making sure the round side of the rocker is down and the flat side for the bolt to rest upon is up?
    i know it seems obvious but people have done it
    Which rockers are these? Stockers have a stop, and you can't do it w/o being a total moron and having the rocker be upside down. Kinda tough.
  5. #25 Re: I hear a tapping from what I think is on of the valves..
    Sure it isn't blown up again since you only replaced one piston?
    I would.
  6. #26 Re: I hear a tapping from what I think is on of the valves..
    Jan 2012
    manville, nj 08835
    yes i haven't had any problems with that cylinder that was on the front of the motor and i had a misfire in the back and alot of noise was coming from the back of the motor so i made sure everything was seated right and not cracked worn ect. everything was fine only thing i did different was i cleaned the threads on the head and the bold and used the red lock tight.. closed it all up ran great for a lil bit but there was alot less noise in the engine bay so it made it easier to pick out that i had the same noise just less of it in the the front so i did the same with checking everything, i drove it 20miles now it sounds like a valve tick or exhaust leak...
  7. #27 Re: I hear a tapping from what I think is on of the valves..
    Probably blew up, again.
  8. #28 Re: I hear a tapping from what I think is on of the valves..
    Jan 2012
    manville, nj 08835
    i would love to start the car and listen to it but my ignition lock cylinder is sticking and turn the key forward and nothing.. it just won't go to the start postion
  9. #29 Re: I hear a tapping from what I think is on of the valves..
    turn the key to run and jump the starter solenoid.
  10. #30 Re: I hear a tapping from what I think is on of the valves..
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    get that 3.2 pulley off man, your gonna blow the engine again. dont go WOT.
    i will take that pulley off your hands too, will trade you my 3.5"
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  11. #31 Re: I hear a tapping from what I think is on of the valves..
    Jan 2012
    manville, nj 08835
    i put all stock parts back on the only thing that is not stock is the intake witch don't matter, i would love to jump the starter but i have a breathalyzer in my car and that would end up getting me into trouble.. i have the part already on its way and just need to get a steering wheel puller and a air bag spring removal tool...
  12. #32 Re: I hear a tapping from what I think is on of the valves..
    Jan 2012
    manville, nj 08835
    i have driven the car for over 3k miles since the piston swap.. hasn't blown up yet!!! lol
  13. #33 Re: I hear a tapping from what I think is on of the valves..
    Mar 2012
    Dallas
    score! lol
  14. #34 Re: I hear a tapping from what I think is on of the valves..
    Jan 2012
    manville, nj 08835
    the lock cylinder was broken but was not the problem for the car not starting it is the ignition switch, and for the valves one bolt for some reason came loose took it out check to make sure the was no bad wearing on it put it back and no more tic... i am getting 35mpg at 47mph now!!! insane love how these cars bounce back so well not even i can destroy this car lol... i have to admit i put the plug wires back it the wrong spot and could have swore that i destroyed something but nope just the wrong firing order...
  1. new hear
    By 5smitz in forum Introductions/Noob Questions
    Last Post: 03-29-2010, 07:54 PM
  2. Would like to hear from everyone???
    By lookinaround in forum Tires & Wheels
    Last Post: 05-01-2009, 09:46 AM
  3. Cleaning valves?Install new valves?
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2008, 10:06 AM
  4. Do you hear somethin?
    By TurboKent in forum General Tech Discussion
    Last Post: 08-07-2008, 11:43 AM
  5. Ever hear the Expression
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 01-01-2008, 02:31 AM
