Thread: Overheating issue - absolutely stumped (Done almost everything)
Results 21 to 40 of 74
  1. #21 Re: Overheating issue - absolutely stumped (Done almost everything)
    South Carolina
    I would go with a 180 thermostat. Not a stupid question cause I have seen it... Is the coolant the right mixture? Too much coolant without the right amount of water will make them run hot.
  2. #22 Re: Overheating issue - absolutely stumped (Done almost everything)
    lets coolant flow before the t-stat opens.
    prolongs warm up time but reduces "shock" upon opening.
  3. #23 Re: Overheating issue - absolutely stumped (Done almost everything)
    Mar 2012
    lakewood
    radiator flush does not work when the rad is that clogged. if you have no flow, think about what blocks the flow. radiator/t stat. you replaced the t stat and bled it. next? radiator. you can pick one up fairly cheap
  4. #24 Re: Overheating issue - absolutely stumped (Done almost everything)
    Mar 2012
    lakewood
    btw, when i replace a tstat i drill a small hole in it
  5. #25 Re: Overheating issue - absolutely stumped (Done almost everything)
    Nov 2011
    Virginia
    How hot is it getting exactly? And if its that big of an air pocket then I think your heat would be blowing out cold. What are the coolant hoses looking like running from your radiator?
  6. #26 Re: Overheating issue - absolutely stumped (Done almost everything)
    Mar 2012
    lakewood
    agreed, if your getting heat in the car your good/good tstat
  7. #27 Re: Overheating issue - absolutely stumped (Done almost everything)
    Cambridge, Ontario Canada
    Car could go to red if i let it. Heat is hot in car. I cant help but think if the rad was clogged why did thnigs seem ok when i pulled the t stat? How can i test the rad?
    2005 E55 - stock
  8. #28 Re: Overheating issue - absolutely stumped (Done almost everything)
    Nov 2011
    NY
    Leave the thermostat out and open the radiator cap... turn on engine and watch for coolant flow.
    If you see nothing moving then you know there's no flow.
  9. #29 Re: Overheating issue - absolutely stumped (Done almost everything)
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    im having this same problem.... except without a tstat i still run hot... but i gotta 180 tstat
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  10. #30 Re: Overheating issue - absolutely stumped (Done almost everything)
    Mar 2012
    lakewood
    anytime you have a plugged rad (doesn't mean completely) you will still have (some) flow. they don't clog completely. when you remove the tstat your alleviating the problem because their is not as much pressure being built up/held back by the tstat. it is like a band aid.
  11. #31 Re: Overheating issue - absolutely stumped (Done almost everything)
    Mar 2012
    lakewood
    like i said, i had the same issue on a 79 z28 i had. it was overheating really bad so i replaced the tstat, when that didn't work i fully rebuilt the engine (with a ton of goodies) and when i got it back on the road and it was still overheating i wiped out my brand new cam and all my bearings. after the rebuild (again) i replaced the radiator and never had the issue again.
    before i rebuilt it the first time i ran it without a tstat just to be able to commute to work in it (it was not overheating minus the tstat)
  12. #32 Re: Overheating issue - absolutely stumped (Done almost everything)
    Quote Originally Posted by thomas mcnulty View Post
    K, going to pull that prick out this week. Once I get it out can I use a hose or something & flush the hell outta it through the filler neck? do i have to be careful on the pressure (ie. fins getting destroyed)?
    2005 E55 - stock
  13. #33 Re: Overheating issue - absolutely stumped (Done almost everything)
    Best way to flush rad while in car? Can i put a hose down the neck and blast?
    2005 E55 - stock
  14. #34 Re: Overheating issue - absolutely stumped (Done almost everything)
    prestone and other company's sell radiator flush, you can put that stuff in, run car as directed, then pull the lower hose. put your hand over the opening or hose depending witch side you pulled, water pump side or radiator side. fill it back up with a hose, and then let if flow out the opening a bunch of times.
    i would think if the water drains slowly, you have a real clogged rad and may need to replace it.
  15. #35 Re: Overheating issue - absolutely stumped (Done almost everything)
    Just went outside pulled lower rad hose and let rad drain. Inserted garden hose in filler neck and blasted away until clear. Did not seem slow. Then put hose into upper rad hose and blasted. it took about 3 seconds and water came flying out. Then connected lower, filled rad and LIM. Decided to start car and a raging force of coolant blew up from inside LIM. So seems like flow is there.
    What next besides getting a flush kit?
    2005 E55 - stock
  16. #36 Re: Overheating issue - absolutely stumped (Done almost everything)
    Fired up again. Overheated and nothing flowing through upper hose. Plus fans kick on blowing cool air so heat cant be going through rad. I drilled six holes in the t stat and she is running ok'ish not overheating. Going to get a third thermostat but different manufacturer.
    2005 E55 - stock
  17. #37 Re: Overheating issue - absolutely stumped (Done almost everything)
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I don't know how many times people have to tell you to buy a new radiator................seriously!?
    For all your 3800 needs:
  18. #38 Re: Overheating issue - absolutely stumped (Done almost everything)
    sucks, sounds like a bad t stat, maybe remove it and see if it over heats.
  19. #39 Re: Overheating issue - absolutely stumped (Done almost everything)
    Update: Different t stat and different manufacturer still problem. Swapped out rad for another used one i got for free from a car where it was working just fine. Car is over heating just a tick less but temps all over the place and i continue to have the issue with coolant flow and bleeding. I crack bleeder rev up and hold and zero coolant will come out. Going to have to drop off at a shop i guess. Any last ideas? Thinking air but i cant seem to get it out.
    2005 E55 - stock
  20. #40 Re: Overheating issue - absolutely stumped (Done almost everything)
    i would remove the t stat, put the housing back on, then take the upper hose off the rad, and see if you are pumping coolant out the upper hose, if not your water pump is most likely dead. rotted impeller.
  1. Stumped on cooling fan issue
    By indy99gpgt in forum General Tech Discussion
    Last Post: 07-01-2012, 10:57 AM
  2. Overheating issue
    By Below Average Joe in forum General Tech Discussion
    Last Post: 11-13-2011, 11:42 PM
  3. overheating issue
    By alreadytooken in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 10:28 PM
  4. 96 grand prix overheating issue
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-10-2009, 12:37 AM
  5. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
