Thread: What year did the factory start using the metal frame intake gasket?
Results 1 to 8 of 8
  1. #1 What year did the factory start using the metal frame intake gasket?
    Nov 2011
    S Fla
    I've been searching on google and other sites, but can't get a reliable answer. My engine blew up, (probable rod bearing-haven't torn it down yet) and I want to get an engine with low miles and a factory metal gasket. I originally thought it was in 2004, but that was just the metal intake manifold. I've also heard 05, 06 and even 07. Does anyone have any documentation to show when it really happened?
    BTW, I have a 2003 GTP, looking to swap in a gen 3.
    Black 2000 GTP. Replaced plugs, wires, maf, IAC, tires, tie rod ends, and s/c oil. Lifetime alignment. No mods yet, just got it. Straightening everything out first. 128,xxx miles
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    I believe they started using them in 2006.
  3. #3 Re: What year did the factory start using the metal frame intake gasket?
    May 2008
    staten island,NY
    If you're buying a new engine you should replace all the gaskets anyway, the gaskets are all metal now anyways, i just did a LIM gasket on an impala SS the dealer gave me the aluminum ones
    Quincy, Mass
    My girls 06 base model has the metal lim gaskets from the factory.
    No more GP 04 Impala SS Indy:
  5. #5 Re: What year did the factory start using the metal frame intake gasket?
    St. Louis
    I think it was mid-way through 05, as I've seen mention that some 05's got them and some didn't. Using up leftover stock I guess. You would be best served to change the LIM gaskets anyway while the motor is out, along w/ the valve cover gaskets and grommets. You will also need injector o-rings for this since you have to remove them to get to the LIM.
    BTW, didn't the 03 GTP come w/ the Gen 3 already on it???
  6. #6 Re: What year did the factory start using the metal frame intake gasket?
    Grand Rapids, MI
    Jake (regorhtims) has an 05 and he still has plastic factory gaskets. You can look at the engine and tell if it's plastic or alum. Just look between the lower intake and the head (visible right at the base of the valve cover). Also, if you want the alum gaskets just because you don't wanna take it apart, it's really easy if you've never done it. Find you a good low mile block and then worry about it lol
    Mercer, Pa
    06 l26 GP junk yard motor (63k miles) had aluminum gaskets.
  8. #8 Re: What year did the factory start using the metal frame intake gasket?
    USA
    06+ has metal gaskets
  1. Engine want start after intake manifold gasket replacement
    By David A Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2012, 09:04 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. Intake gasket
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 12:50 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  5. Car won't start after replacing LIM gasket
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2009, 04:42 PM
