Thread: quick question
Results 1 to 20 of 20
  1. #1 quick question
    USA
    Will a 97 GTP TB work on a 2000 GTP?
    A friend needs one but Im not sure if it will work or not. Let me know
  2. #2 Re: quick question
    Jun 2011
    Detroit, MI
    Yes.
    iLoveSpade
  3. #3 Re: quick question
    The Boss Iceman6669's Avatar
    Jun 2011
    I assume it would... My only concern would be the MAF.... I am not sure if they did anything to that as far as changes go...
    2011 F-150 Yote powered
  4. #4 Re: quick question
    No.
    It wont work.
  5. #5 Re: quick question
    USA
    No.
    It wont work.
    So is it YES or NO?
  6. #6 Re: quick question
    No it wont
    SMGPFC Member #10
  7. #7 Re: quick question
    Its no.
    He needs a 99+ TB
  8. #8 Re: quick question
    Feb 2010
    TN
    Nope 97's are a unique animal mnay parts will only work on that year engine wise, or so I am told
  9. #9 Re: quick question
    Jun 2011
    Detroit, MI
    Oops. I smart.
    iLoveSpade
  10. #10 Re: quick question
    We know
    SMGPFC Member #10
  11. #11 Re: quick question
    USA
    Ok..So will a 2000 supercharger work on a 97 with the 97 TB?
  12. #12 Re: quick question
    Jun 2011
    Detroit, MI
    Yes.
    iLoveSpade
  13. #13 Re: quick question
    USA
    Thanks everyone
    Quincy, Mass
    I put an 00 tb on a 97, just had to drill and tap for a vac port. Why can't you just cap the port on a 97 tb for it to work on an 00?
    You guys need to explain your answer instead of just no it won't work. People can't research if all they find in other posts is " no that won't work" with no explanation.
    No more GP 04 Impala SS Indy:
  15. #15 Re: quick question
    Feb 2010
    TN
    Quote Originally Posted by Swiggles View Post
    I agree with this
  16. #16 Re: quick question
    Jun 2011
    Detroit, MI
    You might want secondary confirmation...
    iLoveSpade
  17. #17 Re: quick question
    What about the vacuum tree of awesome on the 97 blower?
  18. #18 Re: quick question
    USA
    I would think you can bypass that and just go to the boost Solenoid?
  19. #19 Re: quick question
    USA
    Anyone have info on this swap?
    2000 supercharger on a 97? What is needed?
  20. #20 Re: quick question
    Hippo really needs to quit giving car advice and stick to telling the differences between oak and maple leaves.
    If you swap the '97 GTP TB on to a '00 car, most likely it'll toss the P0171 vac leak code for improper MAF readings...I had that issue when I tossed a newer L36 TB on my '98 GT. A '97 TB will work on a 97-98 car...and a 99-03 TB will work on a 99-03 car.
    Now if you go about porting it you'll still need a MAF tune for the car anyways, in which THEN you could use any TB, especially since you're just hogging it out.
  1. Quick question!
    By Amb4 in forum General Tech Discussion
    Last Post: 05-04-2010, 09:12 AM
  2. Quick Question
    By Bakerdd in forum General Tech Discussion
    Last Post: 07-18-2009, 12:03 AM
  3. quick question...
    By virility26 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2009, 09:52 PM
  4. quick 1 HID question
    By wildkyle90 in forum Visual/Body Modifications
    Last Post: 12-14-2008, 04:16 PM
