Thread: KR Questions...
Results 21 to 40 of 55
  1. #21 Re: KR Questions...
    40-15'30'' N 085-40'33'' W
    Yea I have noticed that while reading around here. Guess that should be my next purchase. Then I will have it retuned AGAIN!! oh well part of the learning curve I guess.
  2. #22 Re: KR Questions...
    What should the timing be runnin 60-62mph down the highway?
  3. #23 Re: KR Questions...
    bueller.... bueller
  4. #24 Re: KR Questions...
    high 20's? Not sure i'll check mine out today and let you know.
  5. #25 Re: KR Questions...
    Thanks. I am just curious.
  6. #26 Re: KR Questions...
    I run around 30-32 at 60
  7. #27 Re: KR Questions...
    Mine is 36-38* with 0 kr and no load, not accelerating.
  8. #28 Re: KR Questions...
    Ok, so I went down to PRJ this weekend so he could see why my car has excessive KR. Checked the tuning and all the parameters of the engine and didnt find anything out of wack. Everything looked good, plugs were good, had one wire that was suspect so we changed the end but didnt change anything. Checked the down pipe to sway bar clearance and im good. We were starting to suspect it was just false KR since everything was checking out good. So Paul said just to make sure, run my car down close to empty and put some 100+ octne unleaded race fuel in and see if the KR is still there. If it is there with race fuel we know its a false reading. If it does go away with race gas... Well gonna have to dive in a little deeper. So i got it down to below a 1/4 tank yesterday and put 5 gallons of 105 octane go go juice in her. KR all but went away. Dropped from 7* KR at WOT to about 1.5-2* KR @ WOT with the race gas. Its not false KR. So PHUK ME. We also noticed my car produces about 10# boost at WOT. Paul thinks my short block might have been swapped to an L36 at some point in the past. Guess ill get a compression test done and a bore scope to see if i have a chipped piston... FML. That is all for now
  9. #29 Re: KR Questions...
    Stock pulley.
    Winning.
  10. #30 Re: KR Questions...
    Are you suggesting I take my 3.5 off?!
    Its the most logical way to lower kr.
  12. #32 Re: KR Questions...
    Quote Originally Posted by Jackblack99 View Post
    Well if you can't get rid of the knock without running race gas, then yes. 10psi on a 3.5" means it is flowing like crap. 3.8, 0* KR > 3.5, 7*.
  13. #33 Re: KR Questions...
    I would rather find the actual issue than band aid it. Obviously there is something a miss. Many many guys run a set up similar or the same as mine and alot more extreme and dont have the issue i am having. I wasnt suggesting i run race fuel to cure my KR issue. I want to know whats causing it and fix it. Not take my mods off.
  14. #34 Re: KR Questions...
    Out West
    flow mods, guy.
    Whine with your Cheese?
  15. #35 Re: KR Questions...
    Not every car is the same, it isn't that hard to grasp this concept.
    My buddy ran a 3.3" with just a u-bend delete and a canned PCM. Had like .5* of KR.
    Point being is just because you have "X" mods, doesn't mean you can just run "Y" pulley because "Z" did on his GTP.
  16. #36 Re: KR Questions...
    Im not giving up that easy and going to a stock pulley. Its not like 2 or 3 guys are running my set up.. Its a common, mild set up snd should be and is able to be run with very minimal if any KR.
    Most think kr doesn't matter and you'll be fine because the pcm is simply doing what it was designed to.
  18. #38 Re: KR Questions...
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I tried a 3.5 and went back to the stock pulley because of similar circumstances. No fun chasing the KR.
    Ohio
    Could be alot of things. Couldn't hurt to throw the stock pulley on and see what happens.
  20. #40 Re: KR Questions...
    Well 1. I have an MPS and 2. I dont have a stock pulley. I appreciate the advice though.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. looking into xp cam, have a few questions
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2011, 04:51 PM
  3. AFR questions
    By gtpsleeper in forum PCM Tuning
    Last Post: 04-28-2011, 05:51 PM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. Looking for a new GTP and have a few questions
    By nawarkk in forum General Tech Discussion
    Last Post: 09-18-2009, 01:05 PM
