Thread: Going WOT but boost is NOT.
Results 1 to 20 of 31
  1. #1 Re: Going WOT but boost is NOT.
    GT Level Member fri3dchick3n's Avatar
    Alaska
    To test the fuel pressure properly, I connect to the shrader valve that is right on the fuel rails?
    Ok, I connected FP gauge to the shrader valve on Fuel Rail.
    Here are just some random notes that I took while on the test run. Most might be USELESS but here they are:
    Car off: 38 PSI
    Key On: 48 PSI
    Reverse (0 MPH): 43 PSI
    Drive (0 MPH): 41 PSI
    WOT from low speed: 59-60 PSI
    45 MPH: 45 PSI
    While RPMs drag down to 2k RPM: 40-60 PSI. Like a propeller on a plane.
    60 MPH 0% Throttle: 45 PSI, Apply throttle: Lowers to 40 PSI then jumps back to 45 PSI.
    70 MPH, 2K RPM (Torque Converter Locked In?): 40-60 PSI. Jumps between like crazy.
    70 MPH, 2K RPM (Torque Converter Locked In?): 48 PSI steady. It'll be steady once in a while, Usually jumps around between 40-60 PSI.
    50% Boost: 55 PSI
    50% Boost, Car was only at 3K RPM after I applied more throttle from 2K RPM, While TC was locked in. <-- might be a little confusing.
    And there it is folks.
    At WOT, PSI was always at 60.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  1. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. no boost!!
    By jaygtp98 in forum General Tech Discussion
    Last Post: 04-15-2010, 01:12 PM
