Thanks for the replies guys.. After doing a little more investigating I have found that the vacuum line that runes from the solenoid along the supercharger and then plugs in at the bottom with that T fitting... That rubber T fitting is split where it plugs into the supercharger. Because of this vacuum leak would this be the culprit and causing the code?
Where can I get one of these fittings?
Thanks again.
