Thread: Bypass Valve Solenoid code
Results 1 to 5 of 5
  1. #1 Bypass Valve Solenoid code
    Puyallup, WA
    Hey guys..
    New to the forums. I just picked up a 02 GTP and during the PPI the shop told me that they pulled the code P0243. This is related to the Boost Solenoid. Car runs and drives real smooth, but doesnt seem to be making the proper levels of boost. During WOT acceleration the Info center on the dash only shows half full on the boost gauge.
    What should my next steps be to remedy the issue..?
    Thanks in advance.
  2. #2 Re: Supercharger bypass valve trouble
    Puyallup, WA
    Anyone?
  3. #3 Re: Bypass Valve Solenoid code
    Buy a new solenoid and install.
    OR check the wiring first.
    See if issue resolves.
    If not, its the actuator.
  4. #4 Re: Bypass Valve Solenoid code
    Ohio
    junkyard is your friend lol
  5. #5 Re: Bypass Valve Solenoid code
    Puyallup, WA
    Thanks for the replies guys.. After doing a little more investigating I have found that the vacuum line that runes from the solenoid along the supercharger and then plugs in at the bottom with that T fitting... That rubber T fitting is split where it plugs into the supercharger. Because of this vacuum leak would this be the culprit and causing the code?
    Where can I get one of these fittings?
    Thanks again.
  1. Bypass solenoid/ valve on eaton m90 gen v
    By 05GTPcmpg in forum Off Topic Discussion
    Last Post: 06-06-2011, 06:21 AM
  2. boost bypass valve solenoid wiring
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 09:59 PM
  3. bypass solenoid question
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2010, 05:51 PM
  4. Supercharger Bypass Solenoid
    By DPSJosh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 11:28 PM
