ok awesome I will look into all your suggestions, thanks everyone.
I decided that it isn't a short because it is consistent, it happens every time at idle at 160 degrees or hotter
I did however notice that if I keep on the gas a tad bit it doesn't drop the volts and rpm's
so, I took it to zzp and they said its the adjuster bolt on the throttle cable, and that i need to turn it a bit to have it idle a bit higher, any suggestions on this? Thanks!
