Thread: Issue, please help!!!
Results 1 to 6 of 6
  1. #1 Issue, please help!!!
    grand rapids
    Hey guys, I have a 1997 grand prix GT. I top swapped it using a 2001 grand prix GTP top end. I have an odd issue going on. This happens ONLY at 160 degrees or hotter exactly, and it ONLY happens at an idle.
    When I hit a red light at 160 degrees or hotter, my volts and RPM's drop at the same time together, then bounce back up and it idles a bit higher than it should.
    I have replaced all of my sensors, and alternator, and battery. The PCM has been flashed at ZZP and it has been dyno tuned.
    occasionally I'll be driving down the street and the engine will shut off on me, a check engine light comes on and it scans MAF sensor, I replaced the sensor twice now in case I bought a defective one.
    Could this be a short in the wiring to the MAF? any help is appreciated! thanks!
  2. #2 Re: Issue, please help!!!
    Check for vac leaks, but the MAF can easily cause those issues.
    Could be a short in the wiring for sure.
  3. #3 Re: Issue, please help!!!
    St. Louis
    Would def. check the wiring. May have cut it during the swap. Did it have this problem before the tune?
  4. #4 Re: Issue, please help!!!
    check the wire for the maf at the plug end for cracks or missing insulation, dont be to scared to bend the plug at the end of the wires, they like to crack where the wires go into the plug, if you see bare wire you should change the pig tail for the maf. bad wires will throw a code same as if the sensor was bad.
    and check your grounds as well, take em off wire brush them or use sand paper, bolt em back on. the bunch that bolt to the bell housing.
  5. #5 Re: Issue, please help!!!
    grand rapids
    ok awesome I will look into all your suggestions, thanks everyone.
    I decided that it isn't a short because it is consistent, it happens every time at idle at 160 degrees or hotter
    I did however notice that if I keep on the gas a tad bit it doesn't drop the volts and rpm's
    so, I took it to zzp and they said its the adjuster bolt on the throttle cable, and that i need to turn it a bit to have it idle a bit higher, any suggestions on this? Thanks!
  6. #6 Re: Issue, please help!!!
    St. Louis
    Do you have a cam in it? If not then I don't see why you would need to mess w/ the cable. That just seems strange to me. I would think the idle speed would be controlled by the PCM via electronics, not by having the cable hold the TB butterfly open a bit more.
    I'm no tuning/electronics genious but I find it odd that once it starts getting up to temp it gets a bad idle. Almost makes me think a sensor is getting into closed loop and loses its mind somewhere or something in the PCM isn't quite right.
  1. 04 hud issue
    By Toms04compg in forum General Tech Discussion
    Last Post: 02-21-2012, 03:47 PM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. another issue
    By occrocks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 06:05 AM
  4. 97 key issue
    By Jay7199 in forum General Tech Discussion
    Last Post: 02-20-2011, 07:13 PM
  5. A car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 08-10-2010, 02:05 PM
