Thread: not rod knock but terrible noise
Results 1 to 20 of 28
  1. #1 not rod knock but terrible noise
    SE Level Member pontiacgtp98's Avatar
    Mar 2012
    United States
    Im looking for some insight on my problem with my 98 gtp. noise increases with rpm im thinking main bearings due to the fact that my flywheel or torque converter seems to be screwed up. car was accidently nuetral drop at about 3000rpms and then i had no gears available and now also have this knocking in my engine... my main questions are WHAT TO DO??? and is there any ways to know what the problem is without tearing apart the engine for a rebuild. id prefer to rebuild as opposed to junkyard swap due to the fact the top half has been redone with gaskets. i dont know if trans has issues pretty much wondering where should i start lol thank you any feedback is very helpful
  2. #2 Re: not rod knock but terrible noise
    pull the dip stick, does it sparkle with metal shavings???
    Doing a full rebuild will cost you more than a junkyard motor with all the machining that you have to get done.
  3. #3 Re: not rod knock but terrible noise
    Yoga city
    Well you prolly got more problems, but when it bought I has something goig on I traced it to pulsing injectors
  4. #4 Re: not rod knock but terrible noise
    Mar 2012
    United States
    oil looks fine but the car has only moved 3 blocks and ran only couple times since issue started yet its knocking. u think id be better off getting a junkyard motor preffebly out of a old lady buick?
  5. #5 what is rod knock
    Mar 2012
    United States
    what else could it be because ive heared rod knock and i dont know if thats my issue i hope not but if my engine is knockin am i doomed. fyi its not supercharger thats new
  6. #6 Re: what is rod knock
    Out West
    could be a bad balancer or flexplate.
    Whine with your Cheese?
  7. #7 Re: what is rod knock
    Yoga city
    Take a screw driver and listening to see if it's the injectors?
  8. #8 Re: what is rod knock
    video please.
  9. #9 Re: what is rod knock
    Antioch, IL
    if ur knockin u need a new engine. If ur engine is banging and when you hit the gas it gets worse and louder its rod knock. Leave it in park and floor it until it stops
    2009 Challenger SRT8
    Expert at being gay.
  10. #10 Re: what is rod knock
    Out West
    same procedure for tps relearn ftw
  11. #11 Re: what is rod knock
    Mar 2012
    United States
    flexplate sounds reasonable i dont have any gears and never had and engine issues before this happened.
    Realy gas it till it stops ofcourse in park itll only go to 3800rpm or so
    car was accidently nuetral dropped and then wouldnt move any more. then next day notice this engine noise which ofcourse can be any of the above issues
    lovely trans shop said nothing came up on trans scan but i obvouisly have some issue.. they say engine bad trans bad lol hope not
  12. #12 Re: what is rod knock
    Mar 2012
    United States
    i will get video asap
  13. #13 Re: what is rod knock
    so no forward gears at all? Does it have R, does it move in 1?
    I'd say something inside blew up, possible input shaft or bands.
  14. #14 Re: what is rod knock
    Mar 2012
    United States
    no reverse or 1
  15. #15 Re: what is rod knock
    Mar 2012
    United States
  16. #16 Re: not rod knock but terrible noise
    Mar 2012
    United States
  17. #17 Re: not rod knock but terrible noise
    I merged your threads OP, you don't need multiple ones for the same issue.
    Thanks.
  18. #18 Re: not rod knock but terrible noise
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    Quote Originally Posted by pontiacgtp98 View Post
    sounds like it hurts :/ goodluck bro
    Smgpfc
  19. #19 Re: not rod knock but terrible noise
    Antioch, IL
    ur engine is done. Take another vid of you holding it bouncing it off the limiter until it stops.
  20. #20 Re: not rod knock but terrible noise
    ^^ ever tried to unlock a 3800? You'd never suggest that.
  1. Replies: 10
    Last Post: 09-16-2012, 09:05 PM
  2. Terrible Rattle Noise Coming From Belt Area
    By lsmith3200 in forum Introductions/Noob Questions
    Last Post: 06-17-2011, 07:18 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. L36 engine noise.. rod knock?
    By gpgt98 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2011, 08:58 AM
  5. Terrible knock..need some help!!!!!
    By FooteGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 11:57 AM
