Thread: Terrible knock..need some help!!!!!
Results 1 to 9 of 9
  1. #1 Terrible knock..need some help!!!!!
    Chicago
    so i figured id try out a forum..im new to this so hey to all...i own a 1997 gtp..the other day i was going to replace a failing o2 sensor to clear the code...so i disconnected the battery and the front o2..needless to say i wasnt sure which o2 to replace.. so i crawled underneth and went directly to the rear o2 on the ubend...realized i had a leak right after the cat...so in progress of trying to remove the rear o2 sensor i hit the cat a couple time and the exhaust was shaking quite a bit...so after i gave up because i couldnt get it disconnected i crawled back out connected the battery and the front o2 sensor and decided to go back and get the code read again and find out which o2 was failing..mean while i was driving the car to autozone to get the code read and realized i had a real nasty knock...wasnt sure what that was and the car started to run really really bad...never got the code read because the check engine light wasnt on due to the fact the code cleared its self with the disconnection of the battery...so now im stuck with a nasty knock and a car that wont go over 50.. also i pulled the belt off the sc and spun the pulley by hand and noticed there was about a half inch play before you could actually feel the pulley grab..or give resistance...needless to say i need some help from people who actually know about gp's and know these cars inside and out...please help me out guys...im stumped.
  2. #2 Re: Terrible knock..need some help!!!!!
    Banned - Busted For Scamming
    Feb 2009
    bad s/c coupler.... Welcome To TDC Racing
  3. #3 Re: Terrible knock..need some help!!!!!
    Chicago
    would that also cause like hesitation upon acceleration?
  4. #4 Re: Terrible knock..need some help!!!!!
    Feb 2009
    did you replace the o2 sensor? the one you need to replace is on the rear manifold, not the one you saw underneath, that does nothing for the engine performance.
  5. #5 Re: Terrible knock..need some help!!!!!
    Chicago
    no i never replaced it yet..its been sitting for 3 days. i just want to find out whats wrong before i start digging in. what about the cat? could it be plugged? or do you think its just a coupler?
  6. #6 Re: Terrible knock..need some help!!!!!
    Feb 2009
    coupler for the noise, if you got a code for the front o2 then thats what it is
  7. #7 Re: Terrible knock..need some help!!!!!
    Feb 2009
    if you cant go over 50 and lack of power most likely cat is plugged.
  8. #8 Re: Terrible knock..need some help!!!!!
    Jul 2008
    sumter,south carolina
    posting in the correct section gets more answers...just to let ya know.
    02 GTP with mods 05 GP for DD
  9. #9 Re: Terrible knock..need some help!!!!!
    St. Louis Mo.
    Moved to correct section.
    James Shafer
    St. Louis MO
  1. Terrible stuttering/stalling problems
    By Chernobyl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2009, 11:54 PM
  2. Terrible Vibration.
    By 99LuminaLSC in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2008, 10:46 AM
  3. Terrible Gas Mileage
    By TCO in forum General Tech Discussion
    Last Post: 12-16-2008, 01:01 AM
  4. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
  5. Terrible accident today in St. Louis
    By GeddyLee in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:17 PM
