Thread: Oil problems
Results 1 to 10 of 10
  1. #1 Oil problems
    Rio grande , puerto rico
    HI! so my car keeps leaking motor oil everywhere!!! i fill it up and after 5days its all gone nd im afraid that if i dont checc it at the right time, something serious is going to happen WHERE DO YOU THINK ITS LEAKING FROM? AND WHAT IS THE BEST MOTOR OIL FOR MY GTP ??
  2. #2 Re: Oil problems
    Indiana
    Really?
    Your going to have to give more details than "leaking everywhere". There are a lot of places it can leak from.
    Have you crawled under or looked in the bay to see if you can tell where its coming from?
    The search box is your friend.
  3. #3 Re: Oil problems
    GTX Level Member blackflag's Avatar
    Virginia
    I wouldnt drive it until you get that straightened out. See if you can find it, start high then go low. "Leaking Everywhere" means nothing to us.
    SE Level Member Rudd97gtp's Avatar
    Greensburg, IN
    Means something to me!!!:-). Lots of money lost that **** ain't cheap lmao
  5. #5 Re: Oil problems
    sounds like a oil pressure sensor gone bad to me. when they go they go, i lost 3 quarts in 20 miles when mine went bad.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Pics!
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  7. #7 Re: Oil problems
    Pennsylvania
    If it's that much... gosh. I'd start with the oil filter itself. It that sucker's not on there tight, I guess oil would be spraying everywhere.
    Otherwise, clean the whole engine, let it dry, then run it and see where it's dripping.
  8. #8 Re: Oil problems
    1. If you don't check it every single time you are about to start it, you are making a mistake.
    2. Clean, inspect, fix
    Your description is about as broad as one of them big states to the west of me. Tough to help when you post something like "my car has a problem".
    Ohio
    Old oil filter seal may not have been removed the last change. But like Scotty said, it sounds like a bad pressure sensor
  10. #10 Re: Oil problems
    SE Level Member OldFart's Avatar
    Sep 2011
    Ontario, Canada
    Have you had an oil change (or anything else done) lately?
    And yes, if you don't check it every time you start it - something VERY serious WILL happen.
    Stock 2001 GTP
  1. ABS Problems
    By Logan541 in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 05:49 AM
  2. Having problems, please help
    By marccbr in forum General Tech Discussion
    Last Post: 10-25-2011, 09:39 PM
  3. hid problems
    By jspangler22 in forum Visual/Body Modifications
    Last Post: 05-13-2011, 05:29 PM
  4. three problems
    By jmanrta in forum General Tech Discussion
    Last Post: 03-31-2010, 10:40 AM
  5. More problems?!?!?!?!?
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 11-01-2008, 01:09 AM
