Thread: How Much should a 3" produce
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 How Much should a 3" produce
    SE Level Member Rudd97gtp's Avatar
    Greensburg, IN
    I have just bought this car and it has a 3" pulley. I just installed a boost gauge and it reads 10 psi at wot. Should It make more? I will put the list of wht was said to be done to the car.
  2. #2 Re: How Much should a 3" produce
    GTX Level Member blackflag's Avatar
    Virginia
    I really hope it has more than an intake and catback....lolz
    Greensburg, IN
    Upgrades
    -Ported supercharger with 3.0" and 3.2" pulleys
    -ZZP Modular Pulley System
    -Ported lower intake manifold
    -ZZP Stage 1 throttle body
    -Hydraulic Roller Lifters By Competition Cams
    -Hi-Tech Push Rods By Competition Cams
    -1.9 ratio modified rockers
    -Custom air intake with K&N filter
    -NGK Iridium spark plugs
    -Specially mounted ZZP 1.0 Tuned PCM
    -Rebuilt ZZP transmission with 3.29 Gears, Single Chain, All hard parts upgraded
    -2500 Stall ZZP torque converter
    -Alternator Voltage Booster
    -ZZP Alternator Re-wire
    -ZZP Fuel Pump Re-wire
    -TOG Headers
    -ZZP 3" downpipe
    -Magnaflow converter
    -Resonator removed and 3" pipe back to the stock mufflers
    -Front and rear stabilizer bars
    -Shortened dogbones
    -KYB GR2 struts
    -SSC lowering springs - 1.2" front and rear
    -Anti-pogo washers
    -New top strut plates
    -HID Headlamps and Foglamps
    -Aftermarket blacked out headlamp assemblies
    -11" front rotors
    -Other various upgrades that I am sure I am forgetting!
  4. #4 Re: How Much should a 3" produce
    odd you can run that any only see 10 psi with just rockers and headers.
  5. #5 Re: How Much should a 3" produce
    That must means it's flowing good enough...I guess.
  6. #6 Re: How Much should a 3" produce
    Or the blower has been hookered.
    Greensburg, IN
    It's showing vacuum of 30 is that high I thought 20 was the average correct??
    Greensburg, IN
    And hookerd is??
  9. #9 Re: How Much should a 3" produce
    Quincy, Mass
    what kind of boost gauge is it?
    No more GP 04 Impala SS Indy:
  10. #10 Re: How Much should a 3" produce
    Ah, I'd venture to guess your gauge is defective.
    Hookered meaning opened up too much.
    If you're not seeing KR, your AFR is in the low 11's and you're running at least 15* of timing, I wouldn't worry about it.
  11. #11 Re: How Much should a 3" produce
    Quincy, Mass
    i was thinking the gauge is bad too.
    Greensburg, IN
    Ok it has just a cheap boost gauge and I got a aeroforce gauge ;-) but didn't really kno what to look for I had it on kr and o the whole time
    I think the boost gauge is messed up Cause the aeroforce is showing -9
    On manifold psi and the vac gauge is showing 28-30
    Greensburg, IN
    Arf is?? And I need to look for the timing to be at 15*. I am new to all the numbers of all this. But I think the timing said 23 or something
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Lmao, I'm actually surprised the gurus here didn't tell you that u need more mods to run that small of a pulley!
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
    Greensburg, IN
    That's Wht i was looking to hear!!!!
    Wouldnt it show more boost and why is it not showing kr ?
  16. #16 Re: How Much should a 3" produce
    have the aero set to KR and map then go for a nice series of second gear pulls.
    See if you see any KR and what the aero says your boost is.
    Then change the KR or boost to timing advance and see what thats like while going full throttle.
    AFR is your air to fuel ratio.
    With a ZZP PCM I'd think it'd be setup to run nicely.
  17. #17 Re: How Much should a 3" produce
    you might be lucky. most people cant get away with that pulley on a rocker setup with no headers.
    run it hard, you've got a good setup.
    Orange County, NY
    Edited to change my attitude:
    You should pull the plugs and see wat they look like.
  19. #19 Re: How Much should a 3" produce
    Out West
    He has headers.
    He probably is running 9:1 AFR.
    Whine with your Cheese?
  20. #20 Re: How Much should a 3" produce
    Shouldn't a ZZP be closer to 11?
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. GM to produce new Chevy Impala at Oshawa plant
    By tod1d in forum Off Topic Discussion
    Last Post: 12-16-2011, 10:28 PM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
